SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: can't get universal remote to control home theater system
all your codes for that remote can be had at
http://onlinehelp.verizon.net/consumer/bin/pdf/philipsrc144remotecontroluserguide.pdf
SOURCE: need remote control code forphilips hts8100 to program univ-remot
I have a brand new one!!! I can list it on ebay very cheap. You can e-mail me at [email protected].
SOURCE: idigital RM-810 universal remote code to suit Teac SDB440
http://www.chunghop.com/en/products_view.asp?id=302 contact the manufacter
