Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
I need a diagram of how the belt is to be run and where the tension pulley/rod is located to install a drive belt on a Husqvarna YTH2348 hydrostatic riding mower. 48" deck and 23HP Briggs & Stratton engine.
Posted by rgwest1835 on
MetalHead
    New Friend:
  • 3 Answers
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
http://www.husqvarna.com/us/support/download-manuals/?query=yth2348&types=I&brands=
Posted on Apr 20, 2012
2 Related Answers
Anonymous
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
Anonymous
  • 11 Answers
SOURCE: Problem with the Husqvarna Lawn
http://weborder.husqvarna.com/order_static/doc/usa/2009/I09000/I0902011.pdf
Posted on Sep 06, 2010
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I need to know where the rod arm bypass goes on a husqvarna
Are you referring to the "tension rod" on the mower deck? I think the rod you are talking about is number 114 on the diagram. Take a look at this diagram.
Oct 01, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a model yth2348 mower. How do you adjust the speed of the mower. I have changed the drive belt but it still runs slow.
hydrostatic transmission there is only one throttle setting and that is WFO. if it is running slower than it used to, and the drive belt is snug, then you are looking at a failing transmission.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Will not move forward or back
either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Mar 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 hydrostatic transmission slipping
Check your tensioning bracket, when parked and engine off, lower the deck, look underneath from the left hand brake pedal side and work the brake pedal by hand take notice of the bracket with two pulleys mounted on it that move with the brake pedal being pressed and depressed, if you have vertical? up and down movement opposed to horizontal fwd and back movement your bracket mount and or bushing could be worn out.. Mine was, and after replacement it was like the day I bought it new.
Hope you his helps..
Jul 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Does not engage drive despite pushing rod in
check and see if rod came loose or if belt is off one of the pulleys
Oct 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Sep 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Aug 02, 2009 | Garden
Belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Apr 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt jumped off pullies
l l
l l
l l -
back deck pulley =x
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,980 people viewed this question
Top Husqvarna Garden Experts
bryan st
Marvin
Marvin
dannydoesita
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
