We where watching tv and all of a sudden it turned off!
SOURCE: we were watching the tv
Tv now turn on have no power to the tv at all or the tv power LED light on the tv just blinks.Tries tv unplug,replug the tv back like about an hour,that the resetting tv back to the factory setting.The tv should working again now.If not the tv power supply board it is dead that the board where the power a/c cord plug into it,tv must be repair by replacing components parts or the tv whole power supply board.The tv shop should cost u like about half of the price of a new tv.
SOURCE: tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
SOURCE: My sony triniton kv-32hv6600 32
It seems that it has an internal problem in the machine of his tv has that chequiar a technician
SOURCE: We were watching tv and
Unplug the tv for about a hour and then plug it back in while holding the power button, This will cause it to do a hard reset and either work or product a code via flashing lights, if neither of those have a result it may be the fuse or the power control unit.
SOURCE: TV won't turn on, red
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Must take the aparts to troubleshoot and repair or replace a whole refurbish tv power supply board.U have all the tools and understanding basic electronic also can do basic soldering work?Yes?Take the tv aparts and check the tv power supply board carefully looking for any dying and leaking capacitors components parts.These dying and leaking soon to be dead capacitors parts are alway bulges up or puffing up onto it tops.These dying capacitors components are the causes and the problems for tv power LED indication light flashes and clicking noises.U must replaces all these dying and leakages capacitors components parts to fixed ur tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
