Can i reinstall the mobile software with new how? tell me
Yes, you can reinstall the software by downloading the free software Nokia Suite from the web.
Once downloaded, open Nokia Suite, then follow the steps:
-Connect your C5 phone to the PC using Micro-USB cable-Once connected, a confirmation prompt will appear on your phone;choose"PC Suite" from your phone-Open Nokia Suite, select "Tools", then click on "Software Updates"-You may reinstall the latest software of your phone
*NOTE: Since the phone has been corrupted with virus, it is recommended not to make a backup and backup-restore on your phone. All data previously saved on the phone should be formatted.
JUST FLASHIN IT ON FLASHER BOX
SOURCE: my nokia 3310c software Corrupt after eight days, i want to install myself, req. soft ware
For re-installing the software you need the RM-XX Adapter for your device.
Remove the battery from behind the phone and you will see an RM-XX code.
Buy the Nokia flashing machine and corresponding RM-XX Adapter. Flashing machine comes with the default software for all phones.
Flashing machine communicates with the Computer through an USB port through which you can reflash the phone's ROM.
Personal Advice: If you plan to do service by yourself for a number of phones, you can buy those equipments, or else its better to give it in a shop. Because the equipments costs around $150.
SOURCE: ineed call recorder soft ware for nokia 5310
THERE IS NO CALL RECORDER SOFTWARE FOR 5310 FROM NOKIA BUT U CAN TRY IT FROM 3rd PARTY FEEDS
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Your phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
