Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Gasket appears OK so I think it is overfilling. No float switch, must have a pressure switch or timer for filling. Drain pump activates at beginning of cycle and works fine, but never activates once cycle starts. Water starts leaking about 1 minute into cycle and I shut it down by 2 minutes.
SOURCE: haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way" I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Posted on Oct 17, 2007
SOURCE: pump not draining - Haier portable dishwasher
purchase new pump at www.partsquick.com/haier
about 33 shiped must be able to replace if they sell the pump i have the same problem looking for a diagram to replace pump
Posted on Jan 05, 2009
SOURCE: Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
Posted on May 18, 2009
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
Apr 09, 2011 | Haier HDP18PA Stainless Steel...
Jan 23, 2011 | Haier HDP18PA Stainless Steel...
Jun 03, 2010 | Whirlpool Dishwashers
Nov 21, 2009 | Candy Dishwashers
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Jan 25, 2009 | Haier HDP18PA Stainless Steel...
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
Nov 18, 2008 | Haier Dishwashers
129 people viewed this question
Solved!!! I blew through the pressure switch valve to clear any possible obstructions, then blew into the switch and I heard it activate. Tried washer again and it still overflowed. I noticed on the door behind the panel that a connection was partially unplugged. Plugged it all the way in, turned on the washer, and it beeped repeatedly and the drain pump stayed on. Tilted the dishwasher 45 degrees toward the front and this stopped. Restarted the washer and it ran fine. The pressure switch was working but it was unhooked and not communicating with the control console.
