The pump makes a humming noise w water still in filter.
SOURCE: pinnacle 1.5 hp inground pool pump making a lot of
Is pump moving water at a normal rate and pressure? If so, then you are in need of a bearing replacement. There is no specific lifetime for bearings or shaft seals, however two years would be at the lower end of scale. Have front and rear bearings replaced along with shaft seal.
