Question about Fuji Cameras
Camera won't download to pc
Fujifilm FinePix F20- when I plug in usb cable, the camera goes blank and won't download to pc. The camera still takes pics and it is fully charged, any guesses as to what I can do?
Posted by Michelle Dunford on
Chris Hingee
  • Fuji Master
  • 32,281 Answers
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device, you can then open the folder on the memory card andcopy the photos to your computer.
Posted on Apr 21, 2012
5 Related Answers
Anonymous
  • 2985 Answers
SOURCE: Fujifilm FInepix A500
Reconnect the camera to the computer. and then go through the closure sequence one more and do not unplug the camera untill you are told to do so. Aalso get onto the FUJI tech support team.
Posted on Jun 24, 2007
Anonymous
SOURCE: fujifilm finepix a350
This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
They want to swap it with a E500.
Both of these replacements are less of a camera then the A350.
If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
Posted on Dec 20, 2007
Anonymous
  • 423 Answers
SOURCE: finepix camera
Nope. The battery can only be charged outside the camera.
Posted on Apr 04, 2009
Anonymous
  • 152 Answers
SOURCE: screenon my camera is all white but i can still take photos
Try leaving the battery out of it for up to 24 hours, let it fully reset, then try again.  If it still doesn't work, it sounds like the mainboard could be bad - is it still under factory warranty?
Posted on May 27, 2009
aneesh ch
Aneesh ch
  • 73 Answers
SOURCE: My Fujifilm FinePix F20 digital camera gives me a
problem on lense .remove ur lens on ur camera and cheak the motorgears which are supporting to move lense
Posted on Jul 11, 2009
Why won't the driver for my fujifilm finepix AX300 install on windows vista?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Oct 21, 2012 | FUJIFILM FinePix AX300 / AX305 Digital...
I need to download a driver for my FinePix JV300
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 21, 2012 | Fujifilm FinePix JV300 Digital Camera -...
Fujifilm fine pix f20
There is software you can purchase in an attempt to retrieve your photo's go to www.ebay.com Type: picture recovery a list of sellers will pop up to give choices, also check www.download.com and type same notation.
Apr 22, 2012 | Fuji FinePix F20 Digital Camera
I have a fujifilm s2950 camera and I'm trying to upload photos onto my computer. For the first time yesterday when I plugged the cable into the computer and turned the camera on nothing happened o
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 23, 2012 | FUJIFILM FinePix S2950 / S2990 Digital...
User manual for fujifilm finepix j150w
You may download a copy of the manual here.
Mar 19, 2012 | FUJIFILM FinePix J150w Compact Camera...
I urgently need to download my pictures I the MyFinePix Studio software is not regognizing the camera (FinePix F20). I have Windows XP and I have a newer Fuji Digital camera at repair right now.
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery.
Jul 14, 2011 | Fuji FinePix F20 Digital Camera
I have a fujifilm finepix s5700, bought 2nd hand so did not come with usb cable, cd rom etc, although i have downloadad the instruction manual. i am trying to transfer pictures from camera to laptop. my...
Consider NOT using the USB connection.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Apr 22, 2011 | Fuji FinePix S5700 Digital Camera
Cant find disc for my FUJIFILM FinePix S1800 12 MP Digital Camera. i need the disc in order to download pics to my pc
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http;//picasa.google.com ).
Feb 23, 2011 | FUJIFILM FinePix S1800 Digital Camera
My Win XP based PC cannot connect to the Finepix HS10 with USB cable. I imagine when working properly, an external drive should show, and I should also be able to download the pictures from MyFinePix...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 11, 2010 | FUJIFILM FinePix HS10 / HS11 Digital...
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
