E drive was completely deleted from my dell d620 by an idiot,I need it back
Wait a minute, you gave your computer to someone and they deleted the E drive? What was the E Drive? Most times it only appears when you put something in the USB Port unless you have 2 Disc drives, a cd drive and a dvd drive.
Are you sure your E drive has not been hidden by a virus or infection? It might still be there.
SOURCE: Disable Track Stick
I don't believe so, I believe that it's integrated into the system. However, if it does have an enable/disable function, you will find it in either the device manager, or the system bios. If it's not in either of these, then you won't be able to disable it without removing it completely.
SOURCE: Dell Latitude D620 Full System Recovery?
It's easy to miss the point at which you hit Ctrl + F11. You need to hit Ctrl + F11 at the point you see the blue bar across the top of the screen, it will display www.dell.com. If this is still not working you can use the XP operating system CD to reinstall XP and the Dell drivers CD to reinstall the sound, video, network and other drivers. If Dell didn't send you the operating system CD, you should contact them.
SOURCE: Forgot Admin Password for Dell Latitude D620
i have same problems in my same lattude d620
pls help to break admin password.
my id is [email protected]
SOURCE: Dell Latitude D620, Black Screen/Power On
It is the backlight! That laptop uses a fluorescent lamp. It is bad.
If you look carefully at the screen, you will see the Windows desktop (or whatebver you are running). It just needs to be lit up.... from the back. Tel them to replace the LCd screen or replace the lamp.
Hope this helps!
Testimonial: "Has happened a couple dozen times. Next time the screen blacks out I will look carefully to notice if the desktop is showing. THX"
SOURCE: Restore Factory Settings on Dell Latitude D620 (refurbished)
Restart your system. As soon as the computer reboots and when you see the blue line on top of the screen with a label www.dell.com that the time that you have to hit ctrl+F11. Once Dell PC Restore appears click on the restore button.
Best of Luck
