Question about Fisher and Paykel Washing Machines
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Have a fisher and paykel MW511. Is filling up in short bursts (instead of continuous flow) and won't agitate at all even though it sounds like it's trying too. Will drain no problem, but won't spin. Lights flash 2 and 7 and makes a beeping noise. Anyone know what it is?
Posted by ben_megs on
Greg Stephen
  • Fisher and P... Expert
  • 566 Answers
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Posted on Dec 26, 2013
5 Related Answers
luisa_sgro
  • 713 Answers
SOURCE: We have a Fisher and Paykel toploader, smart drive
Hi just read you posting.Could you please confirm the fault code for me.1st push and hold the WASH TEMPERATURE DOWN button then press the POWER button until the machine gives you 2 short beeps,then release both buttons.Now press the SPIN UP or DOWN button until the HOLD and SLOW SPIN LEDs are both on.Now the fault code will appear in the WASH PROGRESS lights.Please reply to confirm which lights are lit.Are they the same as your 1st posting?To get back to normal operation turn machine off at the power point.Looking forward to your reply.
Posted on Jul 05, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
luisa_sgro
  • 713 Answers
SOURCE: My fisher and paykel WG708 top load washer fills
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Posted on Aug 06, 2010
e-Guru
e-Guru
  • 3917 Answers
SOURCE: My Fisher & Paykel GWL11
Sounds like you probably have a bad diverter valve or diverter valve is clogged with debris or has failed. The diverter valve on a fisher paykel washer moves the water from the drain hose port to the motor.
To access the diverter valve tip the washer back and look in the back right corner. The valve is held into position with two small hose clamps. A wire connection snaps into position on the valves terminals.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 25, 2011
pctech1
Jeremy Moore
  • 1940 Answers
SOURCE: my fisher and paykel gw709
Click on the following images to enlarge. Also, let me know exactly which LEDs are on.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jun 11, 2011
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
My Fisher Paykel washer fills (doesn't matter if it is hot, warm, or cold) in short spurts/bursts starting and stopping, then bursting water in again for a few minutes. However, after about 5 minutes...
Sounds like a rotor position sensor fault. This part is fitted to the motor itself and is a little green circuit board in a white plastic holder. To get it off, first unplug machine from wall then lean machine back so you can get underneath it. You will now see a large round plastic cap 16mm socket to remove that and then 10mm socket to remove the 4 bolts on the motor. Once motor is off you will see the sensor, be careful when removing it as not to damage the wire on the motor itself. You should see a little arrow on the motor where it comes off that is a marker for the long centre stalk of the sensor holder and motor wiring is also marked on the motor itself Y B R for when you put it back together.
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
1helpful
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
2answers
I have a Fisher & Paykel Smart Drive 9 - 6.5kg top load washing machine...model# GW609AU. Will not fill at startup, only short bursts, then shuts down. Can this model be reset?
Can only be reset by unplugging... Sounds like a bad controller or poor connection. Try different water temps, it same problem will need to call a Technician. F/P can tell you who is authorized to fix it. 888.936.7872
13helpful
3answers
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
