Question about Samsung RS2630SH Side by Side Refrigerator
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
CONDENSOR FAN NOT WORKING AFTER REPLACING PCB BOARD.
Posted by RAUL on
Angela Scott
    New Friend:
Where is Samsung refrigerator main board located on model #RS2533SW side by side at?
Posted on Apr 23, 2013
mike cooper
  • 884 Answers
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Posted on Apr 21, 2012
3 Related Answers
Anonymous
  • 22 Answers
SOURCE: Evaporator fan new but not working on samsung rs267lash
Check the defrost thermostat body and see if it has separated a little bit. I have seen the def thermo go bad and cause this problem about 6 times now.
Posted on May 12, 2009
Anonymous
SOURCE: In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Posted on Jul 04, 2009
ImJustAvg
  • 2006 Answers
SOURCE: freezer side of my RS2534WW
Your indications does not make sense! Your unit has ONE compressor that uses ONE evaporator coil to cool both sides. So if the FREEZER side is not cooling the fridge side should not cool either! Are you sure you don't have the freezer and refrigerator sides reversed?
Posted on Aug 14, 2011
I think the pcb is faulty for terminals 3 and4 no condensor fan on cooling no 4 way valve on heating
If you got power going in but not coming out...Likely bad board. Just be sure the board is getting power.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 02, 2017 | Heating & Cooling
None of the evaporator fans are working. Could this be a problem with the main board or the fans themselves?
there is usually only 1 evaporator fan? or do u mean the condensor fan as well? u can check both with a meter for ohms r u saying the fridge still works but no fan operation?
Apr 20, 2015 | Samsung RF4267HARS Stainless Steel French...
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
Condensor fan not working
check for voltage at the motor if yes replace motor if no possible wireing or PCB
Nov 20, 2013 | Samsung RS2630SH Side by Side Refrigerator
I have an intertherm furnace and the circuit board burnt up...replaced the board and the heat works fine....the a/c condensor comes on on cool but the fan will not come on
If you are talking about the fan motor on the condensor then I would check the start capacitor if it is an older model it should have a seperate capacitor in the elec. connection box for a/c condensor fan and compressor. Thank you.
Mar 07, 2011 | Heating & Cooling
Ge Profile refrigerator/freezer \Model PFS22SBSSS
The control board is the problem . Pt # WR55X10656 . There are 2 resistors , one above the other in the area you are refering to . One resistor is for the coil cooling fan ( condensor fan ) and the other is for the freezer fan ( evaporator fan ) . The resistor burnt must be for the condensor fan sincs you said it doesn't apear to have turned in a while . There is no repairing the board with this problem , only if compressor not running but all else work , is the only time a board repair would be acceptable . Replace the board . You have a better conception of this refrigerator and workings , than a lot of "technicians" I know , on this brand and model .
Sep 02, 2009 | GE Refrigerators
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
Refrigerator will not reset after a power outage
just unplug it wait 5 minutes and plug back in. If this doesn;t work, replace the mother board.
David
May 16, 2009 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
578 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
