I was doing homework, and i multipied 2 numbers that should've equaled a decimal and they didnt and on the screen it said "fix" on the left
You can use FIX notation display but specify the number of digits you retain. Press [2nd][FIX] and select the number of digits after the decimal mark (from 0 to 9). However if you do you will constantly have many unnecessary 0.
You can set the display to FLOAT.
To do so, press [2nd][SCI/ENG]. From the three choices you have select FLOAT.
SOURCE: how do I turn off my scientific calculator ti 30x
Press SHIFT then [OFF]. Off is the shifted function of the ON key.
SOURCE: TI-30X IIS contrast adjustment?
try this hit the 2nd button then up or down this should work
SOURCE: The buttons on my TI-30X
Sounds like you have a shorted out circuit card. Try replacing the batteries first to see if the power returns to the keys. If that doesn't work, you will find it cheaper to find a replacement calculator vs sending it to an authorized factory repair center. Hope this helps.
SOURCE: Standard Percentages on TI-30X IIS
You must enter 100+10%100 or 100+10%(100). This will give you the correct answer of 110.
Testimonial: "Thank you very much!!!"
k24674 how do you select?
