Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Hayward 1 1/2 hp super pump will not come on
My pump worked one day and would just not come on the next day. It is straight wired to a GFCI and has a light and timer also. GFCI switch is not being thrown
Posted by lizwooten on
5 Related Answers
james aurienne
  • 93 Answers
SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
Posted on Jun 07, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: new hayward 1 HP super pump runs 1 or 2 seconds,
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Posted on Jul 04, 2009
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
Posted on Apr 07, 2010
A Miller
  • 8404 Answers
SOURCE: I just installed a New 1 hp Hayward Super Pump.
I see what you said ... still I want to say the following: It is to your benefit to keep the motor at 220 VAC ... Since you want to run it on 120 (I presume the motor is internally wired for 120 now - right?) did you change the white wire in your pannel to the neutral bus making the line 120? Also check the motor that it is wired for 120. It sounds to me like you did the line but not the load.
If the line and the load are both correct the next thing to check would be the start capacitor. It should be good since this is a new motor ... but it is not running. Have it checked.
Posted on May 24, 2010
Testimonial: "Thanks for the advice, the current electrical service for the motor is 120, I'm going to change it to 230 for a more economicaloperation. Thanks Again"
A Miller
  • 8404 Answers
SOURCE: I'm need assistance wiring my hayward 2 speed
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Posted on May 25, 2010
GFCI Breaker tripping when turned on
Try running the motor in the dark. You may find it arcs to the chassis of the motor and that is your culprit. Had same thing on a hot tub 10 years ago. The professional techs tried everything for me. i finished the last part at 10pm and turned the motor on and saw the arc then trip the gfci. Good luck
Jun 13, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
My Hayward 1 hp super pump will run for a second and then trip the gfci. What has happened? Thanks.
Normally the GFCI is doing its job.
Water is getting into the internal of the motor.
Try replacing your Shaft Seal
Jul 31, 2012 | Hayward 1HP Super Pump II Inground Pool...
My hayward super pump keeps tripping my GFI. The trouble locates to my pump
It could be an overly sensitive GFCI. If you replace it first, because it is cheaper than a motor, then you can determine whether you need a new motor.
I hope this helps.
Sep 11, 2011 | Hayward Super Pump 1 1/2 - Hp for In...
Need to know which wire goes on the L1 terminal on a Hayward Super Pump 1 hp
The black wire would go on the L1 terminal..that is the "hot" wire ...
heatman101
Aug 04, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
I just installed a New 1 hp Hayward Super Pump. The electrical service is a 20amp GFCI breaker> Old pump was a plug in connection, re-used the existing wiring. I changed the internal connection on the...
May 24, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Looking for a diagram on a hayward pool pump electrical wiring model super 11
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
Oct 14, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
80 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
