My wife has a listing that we are not able to get the code to work to open the box. It worked fine for a few weeks. Now we can't get to the key to open the door. Her client is in California and won't be back for a while. She can have her send a key in the mail but I eventually need to get the lock box off of the door knob or throw it away and get a new knob. Any way to bypass the code ?
The code should mean the memory voltage to the computer has been off at some point in time. Sometimes it is a blown fuse in the box in the engine compartment. I think its a 10amp fuse but not sure. Sometimes the code is set if the battery voltage drops below 11 volts such as when the car has been parked for several weeks or months.
hello! "Element" codes could be: Polaroid, MAG, LG, Vizio. Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code. good luck, Alex.
i had this same problem a few months ago when i replaced the battery. I googled a list of codes for the 04 suzuki forenza and printed off the entire list. Tried each code & the 10th code worked and radio has been playing since then
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
khorak, I've seen this on this model a bunch of times. The inlet valve is weeping water. You need to change it out. The top has 3 screws in the back and it will slide off toward the back. The valve sits on the left side, right up on top. Easy job, part number is 8181694. Catriver
