SOURCE: How do I change the language from japanese to
Click Sony Support and download English User Manual copy, press Menu, settings, main settings in same sequnece and select Initialize camera, this will set camera to default settings and camera will ask time, date and language settings, select English.
Hope this info will help you.
Thanks.
SOURCE: How to change language display on Sony Cyber-shot
Start of Automatic Adjustment Program
Double-click the application file (DSC-T700 Auto-Adj
Ver_1.0r01.exe), and the Automatic Adjustment Program will start.
DESTINATION DATA WRITE
Note: The DESTINATION DATA WRITE cannot be set with other
than the Service board.
1. Function of Each Button on Destination Data Write
Screen
Click the [DESTINATION DATA WRITE] button on the Main Menu
screen, and the “DESTNATION DATA WRITE” screen in Fig. 6-
1-10 will appear.
Fig. 6-1-10
1 [To Menu] button
Return to the main menu.
2 Destination Check button
Current destination setting checked when the “DESTINATION
DATA WRITE” screen started is displayed.
When this button is clicked, the destination is checked and the
display is updated.
3 Destination List
Select the written destination.
4 [Data Write] button
Write the destination data to the camera.
Japanese
English
French
German
Spanish
Italian
Portuguese
Simplified
Chinese
Traditional
Chinese
Dutch
Russian
Korean
Persian
Arabic
Thai
Melayu
Swedish
Norwegian
Danish
Finnish
Polish
Czech
Hungarian
Turkish
Greek
J1 J z NTSC
JE3 JE z a a a a a a a a a a PAL
U2 US z a a a a a NTSC
CA2 CND z a a a a a NTSC
CEE2 a a a a a a a z a a a a a a a a a PAL
CEE8 z a a a a a a a a a a a a a a a PAL
CEE9 z a a a a a a a a a a a a a a a a PAL
CEH UK z a a a a a a a a a a a a a a a PAL
E15 z a a a a a a a a a a PAL
E32 z a a a a a a a a a a PAL
E33 a a z a a a a a a a a NTSC
TH6 Thai a a a a a a a a a z a PAL
AR2 AR a a z a a a a a a a a NTSC
AU2 AUS z a a a a a PAL
HK1 HK z a a a a a a a a a a PAL
CN2 CH a a a a z a a a a a a PAL
KR2 KR a a a a a a z a a a a NTSC
BR1 BR a a a z a a a a a a a NTSC
z: INITIAL LANGUAGE
E
DESTINATION
VIDEO OUT
Default
AEP
AREA
SELECTABLE LANGUAGE
SOURCE: change language from japanese to english
Does this help? "Changing the Language Setting" is located on the first page towards the bottom. It instructions of the symbols you select to reach the language section.
http://www.docs.sony.com/release/DSCW30-W40-W50-W70_rtf.pdf
If this doesn't work could you try using google translate the locate the language section?
http://translate.google.com/#ja|en|
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
