Question about Bose Audio Players & Recorders
Power failure short
When round part of plug on power supply cord is inserted into back of sounddock 2 the green light behind silver cover comes on and blinks then goes off, no sound from speakers. If cord is jiggled around near back of sounddock the power, sound and green light will come on for a few seconds then power off again. Tried a new power cord from Bose but still have same problem ???
Posted by Ben bryant on
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: Won't power up
C702 102K / 2KV capacitor shorted,located near transformer,
possibly partly covered with glue.Use Sony part # 1-161-754-00
102K / 3KV for replacement. Check E994 pico fuse ( 2 amp ).
Let me know by rating my suggestion....T.
Posted on Oct 22, 2007
Anonymous
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
dskum
  • 3 Answers
SOURCE: Bose Sounddock Power connection Schematic
http://www.redflagdeals.com/forums/showthread.php?p=7639870#post7639870
Posted on Nov 09, 2008
Anonymous
SOURCE: blu-ray + bose 3-2-1 system connection?
Connect an HDMI cord from the bluray player to a free input on your HDTV. Then connect the standard WHITE/RED stereo cable from the bluray player into the AUX input in the back of your 3-2-1 system and voila!
You may need to check the configuration of your bluray player to make sure that is outputting stereo audio, for this please refer to the player's user manual. Other than that, you should be alright.
Posted on Jan 16, 2009
thegoshem
thegoshem
  • 61 Answers
SOURCE: Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
Posted on May 06, 2009
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
When you turn tv on the power light blinks green picture comes on for a second then goes off then the power light blinks 4 times, also replaced bulb & one of the fans but cannot reset bulb setting...
In that case the power supply of your television have problem.Maybe there's a loose connection in the power supply board or maybe there's a leak capacitor.If you have no knowledge in repairing television and you want to do at your self, first things to do is to remove the back cover of your television.Look the power supply.Remove the screw and the cover of the power supply and try to resolding the board.Check if there's aleak capacitor.The leak capacitor have rounded shape at the top while the good is flated shape.Replace the capacitor with the same value.
Aug 20, 2011 | Televison & Video
I am having trouble connecting a replacement for power cord. It should fit but it doesn't.
Hi, This may be remedied believe it or not by a little whittleing. Be very careful as you are dealing with a 110 volt a.c. line cord, any signs of silver or copper color may mean the cord has been damaged! It sounds like the end of the cord might be a bit misshapen. if the receptacle on the back of the bose ( where the cord plugs in ) is for example squared off on the one side while the other is rounded off (or vice versa-the receptacle is rounded while cord is flat along one side ) then you may whittle the flat side to match the plug in. also sometimes the plug end that goes into the Bose may need to be notched ( this can bee seen on any number of cords that you may even already have-a little groove on one or both sides right in between the holes at the end ).
Thanks for asking FixYa, I hope i was of some assistance, let us know if so or even if not, thanks again and good luck, Prodzilla.
Apr 13, 2011 | Bose SoundDock Digital Music System for...
Black Screen no sound, Green light blinks for some time then goes red then recycles back to green
Tv have power LED lights indication are blinking and recycle blinking.Mean the tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 02, 2011 | Sony KDS-R50XBR1 50" HDTV
At the base of cartridge carrier,on the right-hand side is a red flashing.It flashes along with the green light on the power-on button,and the blk and colour cartridge button.Struck by lightning.lexmark...
Hello. Hope you got working already. But if you're still having the problem, unplug the power supply (the small black box behind the printer where the power cord is attached) with the other end still plugged in to a known working power outlet. Look around the black box, it should have a green LED on around the silver contacts. If not, properly secure the power cord by unplugging and plugging it back in. Otherwise, you got a defective power supply. Try not to use extensions or power strips, plug printer straight to the wall power outlet or plug it to a different known working power outlet. If the power supply is working fine, plug it back in the printer in a correct position. Properly insert it and make sure it pushed all the way in the printer. If you're still getting all blinking lights once plugged in, your printer might be damaged by the the lightning strike. If that's the case, you can call Lexmark and ask for assistance with that. Well, these are the troubleshooting steps you can do to determine where the problem is. Good luck!
Mar 20, 2010 | Lexmark C530dn Laser Printer
Bose sound dock doesn't work at all
If this is the original SoundDock, the power supply in back is 4 pronged and a pin could be broken. If it makes a quiet thumping sound, then just make sure the power supply is not plugged in upside down (it's easy enough to do).
If this is the SoundDock II or the SoundDock portable, it's hard to say why this would happen, so you should call Bose on that one. There should be an indicator light that tells you when it has power..
Jun 19, 2009 | Bose SoundDock iPod Digital Music system...
When i plug in my sound docking station it makes a knocking sound
The only 2 possibilities are: 1. The power supply IS bad and needs to be replaced. (not the cord, but the supply itself) 2. The 4-prong power supply plug at the back of the SoundDock isn't connecting properly (try flipping it upside down, or making sure "DC power" is written on top if it's a later version.)
If this is the SoundDock Portable or SoundDock II, then the problem is definitely the supply.
Bose can send a new supply for $50+, or repair a non-warrantied SoundDock for $99.
Jun 13, 2009 | Bose SoundDock Digital Music System for...
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
43 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
