Question about Sewing Machines
Cant change stitch setting
Just switched on machine after 16 months of no use and stitch setting wont change from 5P
Posted by June Gregg on
Debbi's Sewing Machine Repair
  • Sewing Machines Master
  • 7,365 Answers
Check to make sure the machine is not set for bobbin winding
Posted on Apr 19, 2012
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
RickE1
Rick
  • 202 Answers
SOURCE: My machine won't make a stitch
Easiest first. Be sure you have it threaded right. My first impression is the needle is in backwards.
Posted on Jul 31, 2008
Anonymous
SOURCE: LED shows 5P or SP
take the bobbin winder post (the silver metal post on the top to the right next to the spool of thread and push it to the left toward the spool of thread. The SP means it is in Spool mode.
Posted on Oct 15, 2008
marianne bags
  • 161 Answers
SOURCE: I am getting an error message of 5P on my DC2007LE
this may be a SP error, which means the bobbin is in the winding position
Posted on Sep 14, 2010
Stuck on 5P
The led light shows 5P or SP and it is stuck there I can't - Fixya
www.fixya.com/.../t25319454-led_light_shows_5p_or_sp_stuck_change
Dec 12, 2014 - the led light shows 5P or SP and it is stuck there I can't change it and the ... Question about Janome 8080 Computerized Sewing Machine.
How to Fix a Thread Jam ' Sewing Machine - YouTube
? 2:03
www.youtube.com/watch?v=TT8qvyb39O4
Sep 7, 2013 - Uploaded by Howcast
Top Rated Products for Every Sewing Project: Singer BeginnersSewing Kit: ... I've gotten longer threads ...
Oct 21, 2015 | Sewing Machines
Stitch Selector will not change. How to get it unstuck?
Is it a mechanical (NOT computerized) machine? If so, your machine probably hasn't been cleaned and oiled and the selector mechanics are stuck. Consult your owner's manual, clean and oil as directed using only good quality sewing machine oil and apply only 1-2 drops of oil each place.
Try this ONLY IF IT IS A MECHANICAL MACHINE: gently try to move the selector bar and see where things should move and apply a drop of oil. Then direct hot air from a handheld hairdryer into the mechanics and see if that helps free things up. You may have to repeat multiple times.
Once it is working again, clean and oil every time you change a bobbin, every 8 hours of constant sewing, or every 6 months if not in regular use.
Sep 17, 2015 | Sewing Machines
How do I fix my kenmore sewing machine. Model # 385. 1960180
Consult your manual, the Troubleshooting section. It should explain what the Code 5P means and how to correct it.
Aug 11, 2015 | Kenmore Sewing Machines
Cant change stitch
if the machine is not set for winding a bobbin
since it's been sitting up for 16 months it may need to be serviced
Apr 19, 2012 | Janome Sewing Machines
IT IS A NEW MACHINE. THE PROBLEM IS... YOU HAVE TO PULL THE MATERIAL THROUGH. THE MACHINE WILL NOT PULL IT THROUGH AS YOU SEW.
are the feed dogs up? check the manual to find where the switch is to change this. sometimes it is a slide on front base or behind the freearm at the back.
other possibility could be stitch length setting is too low , should be 2.5 for normal straight stitch.
if you cant resolve perhaps ring the shop and ask them, maybe the machine has a 'transport' setting which needs to be switched off
Aug 27, 2011 | Brother Sewing Machines
5P is in the screen cant switch the stich or length ect anything what does it mean?
on google a SP error means the bobbin winding, so doudle check all you settings; hope this helps
Sep 11, 2010 | Janome Sew Precise Mechanical Sewing...
LED shows 5P or SP
Oct 12, 2008 | Kenmore 19110 Computerized Sewing Machine
Wont change settings
Take out the needle, tighten the needle clamp screw.
Select the zigzag setting plus the largest stitch width, run the machine quite fast for a few seconds. Turn the hand wheel so the needle bar is at it's lowest, turn power off, get hold of the needle bar and move it side to side half a dozen times.
Turn on power, run the machine again as before.
Go through all stitch type settings zigzag/straight etc and run the machine in each setting.
If after all that the problem is not solved I am afraid you need a sewing machine tech to have a look at it.
It would be interesting to know the make of machine and how old it is, plus when it was last serviced.
Best of luck
Rob
Mar 26, 2008 | Kenmore 15218 Mechanical Sewing Machine
Changing stitches
Mar 09, 2008 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
tina gallow
Are you a Sewing Machine Expert? Answer questions, earn points and help others
