Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23724 Logo
Anonymous Posted on Apr 18, 2012
My freezer is a kenmore mdel #25323725100 , my power went off for about 2 seconds and the alarm will not go off and the quick freeze will not work . HOW CAN I STOP THE BEEPING AFTER 6 HOURS
gaby lomeli
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 10, 2021
gaby lomeli
Contributor
Level 1:
Answers
Questions
0
Helped
445
Points
Were is the battery located
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Apr 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
4826
Points
37
A Big hammer? or have you tried turning it off at the mains for about 15 - 20 mins then back on again that should reset it.
ThanksTalkAppliance.co.uk
3 Related Answers
Anonymous
  • Posted on Aug 27, 2007
SOURCE: Kenmore Freezer Alarm
The battery was the problem in ours. It was doing the same thing. We went through a whole bunch of stuff trying to figure it out too since we bought it as a floor model only two weeks ago. It's just a 9 volt battery.
Anonymous
  • 103 Answers
  • Posted on Jun 12, 2009
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Jul 02, 2009
SOURCE: Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Kenmore upright freezer
order a new seal at the link I provided or ebay or your choice
also check the lid or door adjustmens and obtain specific help instructions at the link I provided
Appliance Repair Help Troubleshooting and Appliance Parts
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Apr 18, 2012 • Freezers
2answers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
