Question about Syntax-Brillian Olevia 242TFHD 42 in. LCD TV
I've tried the method where you unplug the set for 30 minutes,then hold the power button in for 10 seconds,then plug in and that still didn't work. The reset button on the back of the set was of no help either. When I hit the on-off button the standby light will blink off and on every 5 seconds as if it is in standby. Is there any other way to reset this 42" Olevia? Thanks for your help.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Posted on Apr 19, 2012
SOURCE: Olevia 537H-B12 Won't Power ON
try looking at the board inside the TV for bulged capacitors see polaroid thread. this is the problem on the polaroid could be the same here.
Posted on Sep 16, 2008
SOURCE: HELP Can't find manual or remote for 232T Olevia
This manual is for the 232V but its the same functions as the 232T
http://www.olevia.com/ecms.ashx/36cc6c74-60f9-4caf-b6f7-d05024d13e44/Products/232V_English_User_Manual.pdf
Also Olevia made a universal / Learning remote that will work with olevia and also with other device.. the company that is currently selling them are called Amergence Technology ( ph. 866-965-3842 )
Posted on Jul 30, 2009
SOURCE: Olevia 42 inch Flat Panel has power supply
What did you try so far? The main power supply MUST have at least the 5V standby supply section working. This 5v is used by the main control board to send out the command to turn on the main power supply section which will power up the rest of the TV circuits when the power switch is activated either by the power button of remote or on the TV powern button. Look for this 5v first.
Posted on Nov 04, 2009
Jul 02, 2016 | Panasonic Televison & Video
Apr 13, 2015 | Televison & Video
Mar 06, 2013 | Olevia LT37HVS 37 in. LCD HDTV
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Sep 28, 2009 | Sony KDF-E50A10 TV
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
227 people viewed this question
Good news,bad news. Here's what fixed it: I unplugged the set and left it unplugged overnight. The next day I pushed the on-off button on the front of the set 10 times. Then I flipped the reset button on the back of the set 10 times. Then I plugged it back in. Then I used the on-off button on the remote to turn it back on, and it worked. That is the good news. The bad news is now the wife won't let me buy that 70" Samsung I wanted. Thanks again to the individual who suggested using this technique to get the set to working again.
