Acer window 7
The easiest way to find your SSID is to look on your wireless router. The default SSID -- the one it came configured with from the factory -- is always located on the bottom or rear of the router. If the SSID has been changed from the default or if you don't have physical access to the wireless router, you can find the SSID from a Windows 7 computer with Wi-Fi support.
SOURCE: How do I find my Wifi Linksis WRT310N password on my Vista?
try to reset your router:
You may reset to the default settings of the bridge by pressing and holding the reset button on the back panel of
the Bridge for 10 seconds. After that, you need to re-run the setup wizard to configure it again.
for more info check your router's manual
good luck!
Testimonial: "Thanks"
SOURCE: hi i'm using acer E725 and i have installed window...
he if u r using windows 7 then no need to install driver just configure it it will be working because all latest drivers are built in windows 7
SOURCE: I need ato hook
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
SOURCE: i work in a place
Hi.
You may suggest to download the latest wireless card adapter drivers of their
laptops. Generally, that solves the problem.
If updating the driver does not work, Right-click on the Network Status icon
in the system tray:
See if this works.
SOURCE: Wifi discovery problem. I
Assuming you haven't changed your modem's settings...
