Hello friends...i have a 15 lcd of alba company..model no alcd15tv2 ro3sx2...i m having problem with my tv sound as when i connects to tv through rf in sound dosent come...and when i join a dvd or any other through av in then sound is been heard clearly..the problem is with tv no sound comes form it..in tv mode startin chaneels have this problem and last channels which are not clearly viewed their sound is like *************** nly blurr sound comes nothin else.....plse friends help me out of this....waytin fr ur answers....
Posted by cooltaher_ra on
SD Tech
    Top Expert:
  • 14,553 Answers
You have something in the set's menu set wrong--if sound ok with a DVD set is ok---look in menu for something like SAP= most sets have Mono-Stereo-Sap settings.
Sap is secondary audio program which is for a second language to be broadcast (French, Spanish etc.) and if not active there will be no sound on selected channels.
I suspect a careful look will show SAP is engaged and some remotes have a button (MTS etc that will unwittingly get pressed).
Good luck and hope this helped.
Posted on Apr 19, 2012
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
stefanross04
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
KISHORE DESHPANDE
  • 64 Answers
SOURCE: Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
Posted on Jul 12, 2009
William
  • 188 Answers
SOURCE: philips 21rf vardan tv
Check option code's.
Posted on Jul 29, 2009
Anonymous
SOURCE: AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Posted on Mar 18, 2010
Alba 15"LCD TV and DVD Player will not play DVD's, it sounds as though the disc is turning. It will play music CD's
Laser Pickup Unit [Lase head] is weak. There is no repair to this part. Replacement only can be done. Contact any service technician. To replace it, you have to disassemble and take out the disc loading mechanism from the set.
Electro help
Mar 01, 2015 | Alba Televison & Video
My alba tv which is two years old is flickering non stop on every channel and even on the menu
Check the power outlet. Try connecting it to a different power outlet. Look for any jammed buttons on the remote. If the problem persists, this might need attention by a qualified service technician.
Jul 15, 2012 | Alba LDVD1538WDCH LCD TV
I have a Magnavox TV I connected the VHS to, I get picture,but, no sound. How do I get the audio working?
First, you should see "Track" button on the VHS or VHS Remote, press the track severally still sound comes on. But if sound does not come on, you can follow th
There are two connection method you can use to connect our VHS to TV. 1. is RF wire and 2. is RCA (Yellow & White/Red).
Using the RF, Check the back of your VHS, you will see "RF Out", connect the RF wire to that part and the other to "RF IN" of the TV. Then search your TV and there should be a display and sound.
Using the RCA, Check the back of the VHS, you will see Video OUT and AUDIO OUT, connect the RCA wire there and the other part to IN of the, then press AV on the TV remote.
Good luck.
Oct 06, 2010 | Toshiba W403 VHS VCR
I get inconsistent results in using the auto channel search such that I can't synch the TV to the Comcast cable box. Any thoughts? This is a new Pyle 15 in. LCD TV TV/DVD.
use any other connections to your tv, not the one thru rf input.
i.e: audio/video, component,hdmi, etc.looks like there is a tuner issue, plus you'll get a better picture quality by using other options. if that' hd set, you will take advantage of this feature, if not, just improved picture and no hassle to screw in that "comcast's" thick RF cable in.
Good luck,
Alex's TV.
Feb 22, 2010 | Pyle 15 in. LCD TV/DVD Combo
No sound on certain channels.
All the apartments complex have it than it not ur tv.It the cable company signal problem.Tell the maneger call talk to the company check the wiring.
Jan 13, 2010 | Toshiba 19LV610U LCD TV
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Labtop to RF TV?
Hi
If you have a SVHS input on the VCR,or the TV, you should be able to get video that way. You will also need to run sound from the h/p out on the laptop, and corresponding audio connection on the TV/Sound System, or you could still use the laptop for sound. Up to you.
Have a quick look for any SVHS input sockets on the back ot he gear and let me know what you find. Cheers
regards
robotek
Nov 19, 2008 | Televison & Video
Lc-19ad22u
where do you live?
is it connected to to RF or AV
Mar 12, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
