Cannot figure how to get into aux mode to listen to my device
SOURCE: kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. [email protected]
All of the Compatible Kenwood Units will have Bluetooth Printed on the Face in Small Letters. If yours Does not, Go to Crutchfield.com and they will have the Connectors that you need for this to be done. Please Rate My Response! Thanks!
SOURCE: kenwood kvt 717 dvd
Which cables?
Model # KVT 717DVD
FLAT CABLE 22P
FLAT CABLE 50P
FLAT CABLE
FLEX CABLE 50P LOC# FPC1
FLEX CABLE 10P LOC# FPC2
try www.pacparts.com all of this information and more can be found in the model number search function.
Hope this helps.
SOURCE: I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
