Casio fx-300ES Calculator Logo
Chris T Posted on Apr 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I simplify a cubed root of a number on the fx-300ES?
Even if I set it to MathIO and press the SD button, it only shows up as a decimal. Is it only capable of simplifying square roots?
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Apr 18, 2012
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4671827
Points
21595
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Testimonial: "Thanks man. Looks like I'll be doing it the long way. All for the better I suppose. I do need the practice."
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
555
Points
To solve a cubed root problem with the Casio fx-300ES:
Your calculator has dual for almost all of the keys. You can easily see which keys have dual functions the "yellow functions" these are printed right above the key. The square root key is a dual function key and therefore it not only does square roots, it also does cubed roots but in order to use it you have to hit "Shift"
3 Step Instructions;
1. Hit "Shift" key
2. Then hit square root key and enter the value
3. Hit "equal" key
Hope this helps...
3 Related Answers
A
Anonymous
  • Posted on Sep 10, 2008
SOURCE: Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
k24674
  • 8093 Answers
  • Posted on Oct 21, 2009
SOURCE: Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
k24674
  • 8093 Answers
  • Posted on Oct 16, 2010
SOURCE: i dont know how to
You have a key for it. It is marked with the symbol of a radical. Press the key and type in a positive number thaen press the = sign key.
1helpful
When I raise a number to the power of a fraction my Casio calculator shows a decimal answer, what setting will put it in surd forms instead?
Change the output display to MathIO. You may be able to display square roots only: so no cube roots, nor fourth...
2answers
Fraction to decimal
Press the S<->D button located just above the DEL button.
4answers
On my casio fx-82au plus calculator it won't
The capability of these calculators to handle irrational numbers in radical form is limited to square roots. Roots of index other than 2 are always displayed in their decimal representation.
If the calculator IO mode is set to MathIO, square roots will be displayed with the radical symbol. More complicated expressions with square roots might not be preserved and will be given as decimal numbers.
Cant turn a fraction into decimals
The calculator has two input modes: MathIO and LineIO. In mathIO results can be fractions or radicals (if you are calculating roots), and PI appears as PI. The final result may not be a decimal number. To convert such a result into its decimal approximation you press the key marked [S<>D]
My student has this the casio fx 300es, and needs pi to show up as a number not as the pi symbol. How do we do this?
The calculator has two Input/Output Modes: The MathIO and LineIO modes. Line IO is the old input mode where all symbols are written on a single line. MathIO permits fractions to show as they would in a textbook (a horizontal fraction bar and two squares, one on top and the other at the bottom. Pi can be used as Pi and irrational square roots are displayed with the root symbol. etc,,
If you are in MarhIO and you get a result with fractions, radicals, or pi. you can readily convert it to its decimal approximation by pressim the SD key. If you enter some expression with fractions and radicals and you do not want the result displayed with fractions or radicals you press SHIFT = instead of =,
Now if you do not care to have ANYTHING displayed as a fraction, radical or with PI, just set the IO mode to the old LineIO.
To effect that, press SHIFT MODE to enter the SETUP. Select 2:LineIO. From that moment on you will no longer see a fraction, nor a radical nor PI, e,
If you ever reset the calculator, the MathIO mode will be restored as default IO mode.
Answer is in the form of a fraction
What is the question? Do you want fractions or not?
  • If you want to perform exact calculations (that is with fractions and radicals) you should set the calculator Input-output mode to MathIO. Even with this mode set as default you can still convert the final result to a decimal number. This can be done 2 ways.
  1. Result is already displayed in fraction/radical format: Press the [S-D] key to toggle between the two formats.
  2. Result has not been calculated yed (expression still in command line), then press [SHIFT][=] to ensure it is displayed in decimal format.
  • If you do not want fractions nor radicals (roots) just set the default Input-Output to LineIO
To set one or the other IO modes, do as follows.
  1. Press [SHIFT][MODE] to open setUp and select [1:MathIO] to select natural display with fractions/radicals.
  2. Press [SHIF¨][MODE] and select [2:LineIO]
1helpful
While using Casio fx-300ES , I am unable to get answers in decimals. For eg. 3/10...should give 0.3, but the answer is again displayed as 3/10. any way to solve this issue?
The calculator has two Input/Output modes: MathIO and LineIO.
LineIO
LineIO is the old way of entering numbers in calculators and results are always displayed as decimal numbers. Some calculators have a fraction feature and would convert a fraction to a decimal number and back.
MathIO
In MathIO you enter expressions as you would by hand or as you see them written in textbooks.
In this mode, results are by default displayed as fraction or fractions/ radicals.
Conversion
To convert the fraction/radical to decimals you just press the [SD] key. If you press again you cycle through all the available display formats.
So you can (if you want) use the MathIO to manipulate expressions and convert only the last result to decimal. By the way, fractions and radicals are generally more accurate than their decimal representations.
SetUP
If however seeing fractions and radicals is too painful, just set the LineIO as your default mode. To do so press [SHIFT][MODE] to open (SETUP), then select [2:LineIO]
When i type in the cube root i get a decimal answer. i need the radical form of the answer
Configure the calculator to be in MathIO.
Press [Shift][Mode] to open (SetUp) screen.
Select [1:MthIO].
When in this mode, you can still convert a radical/fraction result to decimal by pressing the [S<->D] key.
3helpful
I have a Casio fx-300ES calculator and everytime i push in a math problem it comes out as decimal form or fraction form. I don;t exactly know whats wrong with it, but it never gives me the right answer to...
I understand your frustration, but believe me there is nothing wrong with your calculator. You just have to invest a minimum amount of time to familiarize yourself with its powerful capabilities.
No matter. Your calculator has to input output modes. MathIO and LineIO. MthIO is new and it allows you to enter expressions as if you were doing it by hand (like in textbooks). LineIO is the old way.
In MthIO your displayed results are fractions or radicals (roots) or a mixture of the two. BUT if the screen cannot fit the fraction or radical form, the calculator will use decimal to display the result.
In LineIO you only have decimals results.
To get fraction or radical results configure the calculator to use MthIO. In this mode, if you want a result converted to decimal, just press the SD key. It will toggle between the two.
To set MthIO, press [SHIFT][MODE] and select [1:MthIO]
To set LineIO, press [SHIFT][MODE] and select [2:LineIO]
1helpful
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
