Question about JVC Everio GZ-HD7 Camcorder
Jvc hd7 : connected to tv with hdmi : no audio
When I connect the Jvc Hd7 to my Lcd TV, thru a Hdmi Cable, I can see the video perfectly, but I don't get the audio.
I tried locating any option in the Hd7 menu on Audio with Hdmi, but there isn't any. However, when I burn a Dvd with the Vu40 burner, and play it, it plays both audio & video.
What should be the problem? I would appreciate your help in understanding the issue.
Otherwise, I find the Jvc Everio Hd7 to be one of the finest HD Camcorders in terms of Hd Video Quality, and I'm proud of my eqpt.
Thanks for helping me.
Capt. S. Dutta
Dubai, U.A.E.
  • Anonymous May 11, 2010
    Thanks. I didn't expect this reply. I'll find another way-out. Great guns, keep-it-up.
    Capt. S. Dutta
    Dubai, U.A.E.
    15-11-2008
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: my mac OS 10.5 driver (disc) for Everio GZ HD7 camcorder?????
Hey Brett, unfortunately FCP and iMovie are looking for a device over Firewire or a capture card (whichever you have set up). The driver off of the disk is actually quite useless under any Mac Os 10. Video editing programs unless older or PC based rarely use USB for video transfer hence why none of the apps are locating the camera. Unfortunately you'll have to transfer the files via USB as data and use a program like MPEGStreamclip to transcode them to a file format those programs will understand. JVC has released updated software but it seems to do nothing at all. I hope this helps.
P.S. you may need the MPEG 2 Codec to do the conversions wether you're using MPEGStreamclip or another application.
Ciza
Posted on Oct 29, 2008
Anonymous
SOURCE: Quicktime component for everio download?
http://www.everydayvideo.com/eng/GZ_HD7/index_qc.php
Try this!
Posted on Dec 28, 2008
Anonymous
SOURCE: I can't get my Mac or PC to recognize my JVC everio gz hd7
How can I capture from the camera via firewire?
Posted on Feb 08, 2010
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: I have a JVC HD-FH96
It sounds like it may be either the HDMI port on the TV that has an issue, or the HDMI output port on the Dish Network box. Do you have another HDMI device that you can try in that HDMI 1 port on your TV? HDMI should be very easy to use, you should be able to plug it in, switch to the HDMI input on the tv and it will pick up and adjust to the signal. Even if it was at an unsupported resolution / screen size it would at least have sound. There is definitely something going on with one of the ports... you need to determine which. Hopefully it is the dish network box as they should replace that for free.
It could also be the HDMI cable now that I think of it, do you have another HDMI cable you could test with?
Thanks, let me know!
Tim
Posted on Sep 18, 2010
Anonymous
SOURCE: cannot transfer contacts from htc
Now I found and recommend this third party software called "GodswMobile Contacts Transfer" for Windows Mobile phone to transfer contacts to your laptop computer. Key Features: * Transfer both sim card contacts and mobile outlook contacts; * Including an app for PC to view,add,delete,modify and print contacts; * Restore contacts to any other windows mobile phones; * Backup contacts as TXT file and CTS file; * Backup contacts pictures and ringtones; * Support unlimited contacts backup/restore; * Support VGA and WVGA Screen (such as HTC Touch HD/2 and Diamond/2).
Google "GodswMobile Contacts Transfer V2.1" to free download. OR you can go to GodswMobile Contacts Transfer V2.1 for more information.
Posted on Jan 11, 2011
Memo pad hd7 connection to tv
does your tablet AND your TV have a HDMI outlet? that would be the only way to connect to a TV set
Dec 15, 2013 | ASUS MeMO Pad HD7 Tablet 1.20GHz Quad-Core...
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Jvc hd7. there is "one" pixel "dead".
I don't know if its from the CCD or from your LCD Monitor. CCD dead pixels can be fix but you can't do this at home, need service center because first you gonna need Service Support Software, second you need connecting cable(QAMxxx) and (YTUxxx) Jig. Sorry
Jan 30, 2010 | JVC Everio GZ-HD7 Camcorder
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Downloading problems - distortion???
I have my pc hooked up to my hdtv via vga cable and the video playback is as good as it is if i were to playback from camera through hdmi ,my screen resolution is 1360x768 which is slightly higher than standard hd but lower than full hd but honestly I doubt you could tell the difference.....ps if you have a graphics card that supports 1920x1080p and obviously the tv also, you dont need hdmi out on pc......vga cable does the same job! im running an nvidia 8800gtx
Aug 23, 2008 | JVC Everio GZ-HD7 Camcorder
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
JVC TH-L1 problems....no sound
Almost the same problem. HDMI connections good, sound and video through monitor (LCD TV) , but no sound from the JVC unit speakers.
Dec 29, 2007 | Audio Players & Recorders
JVC Everio GZ-HD7 Camcorder Logo
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
