Incomming calls can't record a message.
If the system doesn't answer the call at all then you need to turn the answering system on. If it answers the call but does not record a message then you need to turn "Announce Only" off. Both of these are in the Answering System Menu options described on page 13 of the manual.
SOURCE: change message
press menu on the base.
use the volume up and down buttons to change to the answ. setup
go to greeting and follow the menu prompts to record a new greeting, then select change to pick which outgoing greeting is played.
you can download a manual from:
http://www.uniden.com/index/manuals_results.cfm?cat=1
SOURCE: don't have instructions to record my message on the digital answering machine
I believe you use the "memo rec" In the silver color on the base, second line of buttons on far left.
SOURCE: I lost my manual and I don't remember how to
Select the model of your phone from the list at
http://uniden.com/index/manuals_results.cfm?cat=1
SOURCE: how do i set the answering system on a uniden
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
The answering system is on and "announce only" is off. The caller doesn't hear the message and unable to leave a message. the recorded message is the dial tone.
