Do you have the google toolbar installed? There are reports that this conflicts with the quicklaunch toolbar, and uninstalling google toolbar will correct the quick launch.
If not, it's likely that your registry has been corrupted somehow, perhaps by use of a registry cleaner?
In any case,
this post describes the various registry fixes that are available for this error. If you are not comfortable working in the registry, please obtain the assistance of someone competent to do so. Make sure you set a restore point and back up your registry with Erunt before performing any registry edits, in case you need to restore your system. Mistakes in the registry can disable your computer.
An alternative might be to run sfc /scannow to check your system files and correct any corruption found.
Here is an overview of it and
Here is a guide that describes how to do so with an sp3 updated disc.
Here is the MS article. I recommend you use this tool to begin with, since there are obvious signs of some registry corruption on your system.
Furthermore, if you have been using registry cleaners,
see this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
