Model # 71-40D
Assuming this water heater is tank type..... Most plumbers will have a cutoff valve located at the water heater or they should have.... if there is not a valve there then the next option will be at water meter located outside or in basement depending on the area you live in......if you dwelling is supplied by a well then you may have a valve in next to the pump or determine what breaker supplies the power to well and turn it off.... ( this will take a little time for the pressure to drop low enough to actually slow the water leak) if the leak is on the tank then you must cut power off to the unit and remove unit or drain the tank to stop the water from spreading( if unit is an electric)
Open following link to identify source of leak, and possiblesteps to repair or replace.
http://waterheatertimer.org/Leaking-water-heater.htmlIf water heater has rusted out within 1 year, then warranty will cover replacement water heaterIf it has been longer than one year, then warranty might be pro-rated
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
SOURCE: Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
SOURCE: My Rheem hot water heater stopped putting out hot
If you are not familiar with the element, I would get someone that is familiar with one and have them do it. It's not something I would recommend you do based on your question. There's electrical, pressurized water tank, and a whole lot of water that may cause you to have a worse bad day.
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
SOURCE: my rheem water heater model 81v520 is leaking
The tank may be corroded and you may need a new unit. Check to make sure that the water is not coming from any of the water connections that are higher up on the unit. Also check the drain plug to make sure it's secure. I don't know the age of the water heater but it may be time to replace. Most people don't know that water heaters require maintenace (draining the tank to remove sediment) from time to time.
