You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : -http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
SOURCE: Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
SOURCE: installation failure, canon pixma ip 1600 driver mcd 1.0
I have a windows vista and don't know why a cannot install my printer wich is a canonPixma i1600.Can you give any help.Thank you.
SOURCE: canon pixma ip1300
follow the link to download the driver
http://software.canon-europe.com/products/0010383.asp
select operating system and language.
Mark
SOURCE: canon pixma mx 700
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
SOURCE: Hi, I have the Canon
Installing ink cartridges:
Make sure that the machine is turned on, lift the
Scanning Unit (Printer Cover) with both hands, then pull the Scanning
Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
Removing Ink Cartridges:
<2> The ink cartridge is installed properly.
hope this helps
