I am running Windows XP SP3 on a Lenovo T410 laptop. I use a PNY 8GB Attache USB 2.0 flash drive. I have no trouble using the drive but when I try to "safely remove" the device I get a Windows message saying that the drive is in use and can't be ejected. Even after I close all programs and windows I continue to get the same message. The only way I can remove the device is to shut down or restart.
Right click in the bottom toolbar select task manager to see whats runnng in applications also in processes to see whats ticking over Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
it might be your antivrus or another program thats runing
also
try right clicking on it windows explorer select eject
also you might have to resore it to default status
Right click on your drive select properties then on customize restore Default in W 7
hope this helps you
SOURCE: flash drive ejecting problem
well its not a big problem, when u finished ur work dont right click on the icon just bring the mouse cursor there and click once option will apear ...safely remove ur deive.. click it and remove ur flash drive
SOURCE: Need Windows ME Driver for PNY USB 2.0 Flash Drive Attache
Here's what you can do,
Download the files using the these links,
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbauth.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbhub.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbmphlp.pdr
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbntmap.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbstor.sys
http://www.usbman.com/WebDrivers/WinMe%20Sys%20Files/usbui.dll
Put all these files in one folder and when windows ask for the drivers, select the option to manually serach for the drivers. And point the search to the folder where you saved these files and it should fix the problem.
If this does'nt work, please let me know.
