Question about Ryobi Cultivator
Ryobi ry64400 tiller tines won't move engine runs fine
Tiller starts but when i engage blades eng stalls. tines frozen won't turn
Posted by bryan harris on
  • Anonymous Mar 29, 2014
    motor is loud, tynes barely move
mike butler
    Brigadier General:
  • 6,468 Answers
Then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Posted on Apr 21, 2012
2 Related Answers
imnicerthanu
SOURCE: Ryobi Tiller, model RY60511A, will not start. Air
mine was a total pain. I yanked on the rope so many times, it flew out of the keeper,and when I replaced it I ran it UNDER the fuel tank cutting a slot in tank. I also blew out the primer bulb. AFTER the replacement tank I arrived, I discovered rolling the machine forward helped the flow to carb and did not require priming. Now I need to fix throttle cable. But all in all, a tough little machine.
Posted on Mar 07, 2011
mickey813
mickey813
  • 472 Answers
SOURCE: my Ryobi tiller starts but will cuts out when you
SOUNDS LIKE IT NEEDS A FULE FLUSH AND THE CARB NEEDS CLEAND AND SET
Posted on Oct 14, 2009
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Ryobi ry60514 is frozen.
Does the engine turn over? If not then it has most likely seized. If the engine turns but the blades won't then make sure you didn't wrap something around the tines causing it to bind up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 17, 2013 | Ryobi Cultivator
Tiller shuts off when I engage tines. I have changed the oil, cleaned the fuel tank out, checked the plug, I just need to know what adjustments, if any that I need to make.
Is the gear box full of oil? If it is dry it will bog down the engine and stall it. Will the engine run at full speed without the tines engaged? If it doesn't maybe the full throttle mixture screw needs adjusted out CCW a little.
Oct 19, 2011 | Garden
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Ryobi Cultivator Logo
1,037 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
john h
ROB
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
