I entered the codes which are in the manual, but the codes dont work. I have daewoo tv. 1 code olmost worked, but if I press, the buttons, some works, some dont, and they work wrong way...
Try these codes.
0130 0004 0009 0100
................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
....... 0017 0010 0126 0018 0127 0019
Direct Code Entry
Code Search Method.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
SOURCE: Tried everything, but can't find the right code to work.
While this isn't really a solution, I have the manual and it doesn't list an Emerson DVD/VCR (EWD2204) that I have. I can't get it to work with my VCR. I bought the RCE Universal remote (RCU703SP) at Lowes (in 2008). I can't help but notice that the date on the package is "2004 Thompson, Inc." I know that the DVD/VCR is newer than that. Perhaps this remote is a bit old (explains why it was cheap?) Anyway I did find a site that you can get the codes like in the instructions: http://remotefinder.rca.com/default.aspx?site=rca so hope this helps.
SOURCE: i need code for samsung remote code for tv
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
SOURCE: small universal remote control 'TOTAL control' brand
I downloaded the complete user manual for free at Forum: www.remotecentral.com
still, cant make it work:(
