I have looked in the manual and it says that the tv is able to read movies off a usb. Maybe it is connected to what format the movie is in?
LG 32D450 LCD TV doesn't support video playback from usb. The USB 2.0 input of this particular model can only read jpeg format (photo/snaps) and MP3 format for music playback. please click the link below and see the technical specification and USB input.. http://www.lg.com/us/tvs/lg-32LD450-lcd-tv
SOURCE: My lg lcd tv has a usb port but only recognises
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
SOURCE: usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
SOURCE: Trying to connect an ipod to LG plasma tv via USB
Hey - I'm in the same boat, did you get it working? I connect and get the USB menu up, but the tv says that the file is corrupt, even though the iPod works fine when it's not connected to the tv.
SOURCE: when entering my usb stick or looking on the on
some OS's do not give that option when plugging in a usb device.... however if that is the case then click on MY COMPUTER > REMOVEABLE DRIVE (Whatever your pendrive is located) Then click on the movies :)
SOURCE: I Have a brand new LG 32LD450 LCD tv and I am
the television may be defective and you can call the company and ask for a repair if its still under factory warranty
Notes about using USB
= Before using this function, make sure that you select the correct source (USB) and insert a USB storage device on
the TV to view compatible photo, movie and text on the TV screen or play compatible music through the TV.
= If the connected USB HDD does not have an external power source, it may not be detected. Be sure to connect the
external power source.
= To avoid losing the data on your USB device or damaging your USB device, it is recommended that you back up your USB
device data.
= The USB multi media playing menu may vary in different situations.
= If you want to pull out the USB device, please exit USB mode first.
= For instructions on using your USB device, refer to the owner's manual for your USB device.
= Never remove the USB device or turn off the TV while using the USB device. Doing so may result in loss of data and/or
damage to the USB device and/or TV.
= Certain types of USB devices may not be compatible with this TV.
page 21 also shows hitting USB button on remote (lost that?)o
and see photos on a USB or a movie. Photos , movie or text it tells.
here is my wild guess on the model.
https://www.manualslib.com/manual/918457/Sinotec-St-29me70h1.html?page=23#manual
the TV has multimedis player inside, this works for USB.
page 26 covers what movie FILE formats work.
format the usb stick as Fat32 is one safe first guess and try.
good luck with using USB. (the manuals on TV are very very limited on (what it needs to work right)on this TOPIC.
one poster back 2014 this brand
tells. supports fat16/32,and NTFS. and JPG,PMP and PNG photos. and what page 26 tells you,.
