Question about Texas Instruments TI-89 Calculator
Ti-89 titanium diagnostics
How do you turn diagnostics on on a TI-89 Titanium graphing calculator?
Posted by Jiayang Li on
k24674
  • Texas Instru... Master
  • 8,092 Answers
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
Posted on Apr 17, 2012
5 Related Answers
Anonymous
  • 10515 Answers
SOURCE: my ti-89 titanium will not graph
I had this problem. What fixed it for me was clearing all of the lists in the Statistics application and also in the stat app in the f2 pulldown menu select Plotsoff. After that it worked fine.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 14, 2009
Testimonial: "Thank you! Works now."
raklein62
Richard Klein
  • 360 Answers
SOURCE: how do i type a negative and backslash on my ti-89
On the left side of the enter key is the negative sign (-). The backlash is 2nd and 2 key
Posted on Aug 26, 2009
Rommel Balcita
  • 749 Answers
SOURCE: TI-89 titanium does not turn on
have tried replacing its batteries!
Posted on Nov 04, 2007
raklein62
Richard Klein
  • 360 Answers
SOURCE: When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Posted on Sep 22, 2009
How to restore memory on TI-89
Hard Reset means reset. Everything gone and no way to recover it.
The screen on my TI-89 Titanium turned blue after replacing batteries? How do I fix this? It turns on and off but does not respond to any other buttons.
If you cannot see anything on the screen, you may need to adjust the graphing TI 89 Titanium calculator contrast :
1.To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark.
2. To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light.
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
My TI-89 Titanium won't graph sin, cos, or tan?
Set your calculator to RAD mode and then graphing functions.
See example for y=sin x
1helpful
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
I accidentally resetted my ti-89 titanium
Use the TIConnect software to connect the calculator to the computer.Then in the TIconnect main window you can drag and drop the applications you downloaded from education.ti.com. They will be transferred to the calculator.
I cannot understand why you cannot graph normally since the graphing is not an application, it is part of the OS.
While you are connected to the Internet and to the calculator, you may want to reinstall the OS directly from education.ti.com to your calculator
Hope it helps.
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Filipe Polido
Filipe Polido
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
