I am in desperate need of some solutions to help me fix my laptop, when i push the power button the screen is blank but a geen light and two amber lights are showing aswell as the wireless. i have checked the power lead tried hard reset bios battery reset swapping rams etc please help before i beat myself unconcious with this machine. many thanks :)
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
SOURCE: Asus Eee pc 900 can't boot (blank screen)
I had the same problem and from other forums I found that you have to remove the memory and short cmos . To short cmos I use screw driver to connect two copper pads.
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen.
Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
SOURCE: DIP SWITCH BIOS RESET POSITIONS SONY VAIO VGN-fs660
There are 2 ways you can reset your bios.
1.
On the motherboard there is
a small watch battery. Remove this battery along with the power cable
from the power supply. Hold down the power button to fully discharge the
system. Wait 2-3 minutes then reinstall the battery and plug in
your system. Your reset is now complete
2. Some motherboards have a 3
pin jumper by the battery. Lets say that the jumper is on pins 2 and 3.
Remove the jumper while the machine is OFF and place onto pins 1 and 2.
Power on your machine for a minute. (Note: Your system will not POST).
Shutdown your machine and put the jumper back to pins 2 and 3. Your
This is a great troubleshooting
step for those of you having POST issues or no POSTing at all. Like
other troubleshooting steps, this will not always work but usually will
depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
also the fan is working ever so quietly and i can hear a small amount of noise from the hard drive , i have tried to attach to an external monitor but hasnt helped.
ok changed the hard drive for a different 1 and i am now getting no lights but the dvd draw is now opening and it is making more of a healthier noise ! i have taken the screen completely off and plugged into a external monitor but stil blank screen- some1 must know something i could try surely. . . . . . . .come on i have never signed up to a forum b4 and it will be my lasyt timeeeee soooonnnnnnn !!!!
