Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
My KitchenAid bowl keeps coming loose when kneading dough. Any solutions?
I use it weekly. Usually kneading around 4 cups of flour.
Posted by MDan on
MendingShed.com
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
My KitchenAid bowl keeps coming loose when kneadin - 12448327-25j1o4dy5jqip5urp5sucdth-3-0.jpg
Posted on May 05, 2015
John Fink
    Champion:
  • KitchenAid Expert
  • 202 Answers
If giving the bowl an extra twist when mounting it, you may need a new screw cap (the piece the bowl locks into). This is a part easily obtained.
Posted on May 02, 2015
5 Related Answers
Anonymous
  • 135 Answers
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
dewan nafees ahmed
  • 1894 Answers
SOURCE: 6QT KITCHENAID MIXER DOESN'T POWER ON
put some lubrication to it...
Posted on Feb 17, 2008
QuietRiot
  • 145 Answers
SOURCE: KitchenAid Parts
Given the age of a 3-C stand mixer, finding additional parts for it will be exceedingly difficult. The best recommendation is through E-Bay or antiques stores - a specialty dealer. Kitchenaid parts distributors will no longer have anything in inventory for the 3-C mixer.
Posted on Jul 08, 2009
hslincoln
Howard Lincoln
  • 235 Answers
SOURCE: Motor now has two speeds: off and 10 (highest) -
Hi REEDKL, Merry Christmas and Happy New Year! Based on your mixer’s symptoms, my first thought is that your mixer’s internal controller assembly (the speed knob), has gone bad. The inspection and troubleshooting of the control assembly is something you can do yourself, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer.
If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in this case, KP26M1, and then select the last file: KP2671XWH3.pdf (325.07 KB) that appear under Parts List (21). Check to see that it matches your mixer model.
Turn to page 4, Case, Gearing and Planetary Assembly and locate Illus. #8, Control Assembly. This is what you’re looking for when you get the top (Illus. #1) off the mixer head.
First check to see if any of the connections have come loose. If everything looks tight then you probably need to replace it. Unfortunately the whole controller assembly is on a little PC board filled with resistors, capacitors and diodes, which was not meant to be 'home fixed' and where my ‘electronic expertise' ends. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
Although you don’t need to get further inside your mixer to make this repair, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer that you might want to keep in your ‘toolbox’, should you have to delve inside your mixer in the future. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able replace any part to your KA mixer.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Jan 04, 2010
Testimonial: "This is great information! I never expected to find help like this. Will move on it. Thanks!"
justinbur167
Justin Burnett
  • 257 Answers
SOURCE: Motor head locking lever is
Hello Flyfishing19,
The problem that you are experiencing is due to the torque that is put on the head while mixing dough. The lock is still working fine, although it is getting wear. You can replace the locking mechanism. However, it will work for a while longer. If you want to change the mechanism post back to this thread and I will be happy to locate you one and explain how to change it.
Posted on Mar 06, 2011
Kitchen aid mixer has a scream when using dough hook.
A little pin or setscrew or key has failed. Maybe a gear has slipped out of place. Anyway, the thing needs to come apart to find out what happened. When taking things apart, line up each item off in a tidy row, put screws in little containers near the part they fit.
Repairclinic.com may have instructions, and probably have the parts.
Nov 26, 2013 | KitchenAid Food Mixers
Delonghi DSM7 Stand Mixer won't start after overheating. Is there a reset button?
take it in to an appliance repair shop for a proper diagnosis and quote but it is probably not worth repairing ( armature and brushes )
Apr 09, 2017 | DeLonghi DSM7 Stand Mixer
I have the KitchenAid 5 Qt HD Professional stand mixer. When I securely attached the bowl to the bowl support arms (I hear the bowl click to the back) and use it to knead bread (the flour amount well...
hello step ..... yes. You may have to adjust the height of the bowl a wee bit as it sounds like the dough hook is hitting the side of the bowl..
It tells the steps in your manual.
Easy to do.
If you don't have the manual you can download it for free here http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
Joe
Mar 12, 2011 | KitchenAid K5AWH Stand Mixer
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Need instruction manual for Waring Primo Pasta maker
Here is one:
http://kitchen.manualsonline.com/mdownloads/f94c65cf-4df5-41e2-aae4-7021aed15dfa.pdf
Could someone tell me how much flour the flour cup holds, compared to a regular measuring cup?
Apr 02, 2009 | Food Mixers
My varimixer R30 hook doesn´t seem to reach out far enuff to mix satisfactorily. Can the hook change shape just like that ? Or is the hook for some other kettle ?
This is a dough hook and would typically only be used to knead dough. Therefore, the extra clearance makes sense for kneading dough. For other mixer jobs, use other attachments.
Mar 06, 2009 | Food Mixers
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Bread hook use
Use it to the side. This will pull the dry ingredients off the bowl. If the dough is coming out lumpy, make sure you follow the recipe exactly. Putting dry into wet will give different results than putting wet into dry. If this doesn't end the lumps, try a different type of flour.
Oct 15, 2008 | Sunbeam Heritage 2346 Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
9,128 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
