SOURCE: hotpoint refridgerator model csx27d
Friend,
ngfam1 At your service!
NEEDS SERVICE AND PARTS. PERHAPS ALL NEW ICE MAKER!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
SOURCE: How old?
Check the metal tag inside inside the fridge, not the paper sticker in the freezer. My Hotpoint has both but only the tag in the fridge has the full model number. Correct model number tag should also have the serial number listed on the tag. Also some models will have a tag on the back so check there too.
Since Hotpoint is made by GE you may also want to look on GE website: http://www.geappliances.com/service_and_support/
On their site I found a luink to a PDF scanned file of the user guide for CTF19 models. http://genet.geappliances.com/DocSearch/pdf/39-6193.PDF
Last page of the PDF lower left is dated 9/82 this couls be close to the year of your unit.
Good luck.
SOURCE: TOP freezer Hotpoint refrigerator NO ICE MAKER
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: HOTPOINT Refrigerator HSS25GFPE WW -
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
