SOURCE: Connection of Paradyne 6211 to iMac (OS 10.5) via Ethernet
If you connect by using LAN port (RJ 45) you don't have to install driver. However USB connection will require driver. Do you have Ethernet adapter installed to you iMAC? If you have it will be resolved easily without using USB port. Check the following link for connection instructions
http://www.fixya.com/support/p200812-paradyne_6211_a2_200_router/manual-18800/page-18
If physical connection is successful you can go to internet browser type 192.168.1.1 and check your modem's settings. Please post if you need further assistance
Good Luck
SOURCE: Bridged Mode
Verify this with your ISP, but if you go into your modem settings, click on "Advanced Setup", click on WAN, when page opens, click "Edit". After clicking "Next", you come to the page labelled, "Connection Type". It is there you select what mode you'd like it to work in. When you are through selecting click NEXT till you get to the page with the SAVE button. Click Save and wait for page with FINISH to come up. Click FINISH and wait for the router to reboot(2 mins). Please write down the previous settings so you'll be able to undo whatever you do.
SOURCE: 6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
SOURCE: what is the username and password for paradyne adsl2+ 6211-A3-304
The default username is Admin and the password is Admin. Both are case sensitive
