My Samsung HT-D5530 3D Blu-Ray when in Standby mode keeps turning itself on, you press the Standby Button on the remote, it stays on Standby briefly and then 'Turns itself on
Posted by Mark Herman on
    Top Expert:
  • Televison & ... Master
  • 76,416 Answers
Check its mechanism for fault.
Posted on Apr 16, 2012
5 Related Answers
Anonymous
SOURCE: region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
Posted on Mar 22, 2009
Anonymous
  • 4 Answers
SOURCE: New Sharp BD-HP16U won't play Blu Ray Discs
You need to force the player to the the Top Menu of the disc.
The way to do this is: load disc, wait until it says "Reading Completed" (about 1 minute).
Wait for the PLAY icon ">" to show in the upper right corner (this may take up to 30-40 secs).
Once you see the ">" Hit the STOP button on the remote to get to the player's splash screen.
From the Sharp splash screen Hit the "Top Menu/Title List" button on the remote and wait for the circulating dots and then the disc menu appears.
Play the movie from the menu and you should be good to go.
~JC
Posted on Sep 16, 2009
Kevin Braid
  • 382 Answers
SOURCE: My Blu-ray keeps saying no disc.
This can be caused by a number of different things, some simple ones are:
- Unplug for 5 minutes then replug, this will reset the processor and it may smarten up (just like rebooting a computer)
- Take the unit apart and using a Q-tip and lens cleaner gently clean off the lens of the laser...only do this is you feel comfortable. If there is a hair or obstruction on the lens it will not read discs. If it is still under warranty, send it in first before you take it apart, it may void warranty.
- If the above two do not work then the transport mechanism may be defective and the repair would be around 100 -150 dollars, which is probably not worth repairing and it is best to look at a replacement machine.
Hope this helps!
Posted on Jan 20, 2010
Anonymous
SOURCE: CAN'T PLAY BLU-RAY DVD ON SAMSUNG DVD BLU RAY PLAYER
I have a Samsung BD-P1600 and was having similiar problem...played thru previews but would not play. Instead of just powering off/on... I pulled the plug on the ac cord out and left it out about 20 minutes and it now works !
Posted on May 17, 2010
Testimonial: "Thanks for responding. It's working!"
Anonymous
SOURCE: My samsung blu- Ray bd-p1590 won't turn on
The Tech told me to unplug my blu ray. Then push the middle button on top for 10 seconds to reset it. Hope that helps. I didn't help me.
Posted on May 25, 2010
Volume keeps going down by itself
Also without manual operation or only by remote control if its doing it by manual operate there is something in a manual operating matrixboard IC or button hangs for control there is an motor on the volume it will get a command by remote control but if something could happen in the attenuator itself ??? it must be measured or measured and unmounted.
SAMSUNG HT E6500W ZA Service Manual free download schematics eeprom repair...
be aware of this .. down under the picture you see this Click the preview picture to see bigger size. The preview is worse quality than the original pdf. down under you see the word [ processing ] wait until there is to read [ Get Manual ] because its not easy to understand where to get
Jul 20, 2016 | Samsung HT-E6500W Blu Ray Home Theater...
My SWA-5000 is not connecting to my main unit, which is a samsung blu-ray home theater system. I have already tried what it has said on the manual, but it still wont turn on, it is just on standby. Please...
start with the main unit turned off. Press and hold the button on the back of the swa-5000 module until the light on front starts blinking fast. Then point the remote at the main unit and press 0-1-3-5-ENTER. The standby light on the main unit should turn off then back on. Turn on the main unit and it should find and link with the wireless amp.
Dec 20, 2014 | Samsung Wireless Amplifier Swa-5000 For...
Samsung 1080p player is not opening to release disk
To unlock the Blu-ray player, follow these steps:
  1. Press the Stop button to place your Blu-ray player in stop mode.
  2. Press 4-8-2-7-3 on the remote control. Lock Off will appear in the upper left corner of the TV screen.
  3. Press the eject button on the remote control.
  4. The disc tray opens on the Blu-ray player.
If this does not resolve your issue:
  1. Unplug the player and hold the power button for about 20 seconds.
  2. Connect the power cord again and with no disc in the player, press and hold the Stop button on the panel until your TV displays the message, "Resets all settings to the default values". After a few moments the Player will turn itself off.
Jun 30, 2014 | Samsung Televison & Video
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
How to unlock dvd
Here is how to unlock the HT-DS1000:
Step 1) Disconnect your player from its power source for 30 seconds
Step 2) Reconnect your player to its power source
Step 3) Press the Power On button on your remote control
Step 4) Press the Enter button on your remote control
Step 5) Press the 8 button on your remote control
Step 6) Press the 4 button on your remote control
Step 7) Press the 2 button on your remote control
Step 8) Press the 6 button on your remote control
Step 9) Press the 9 button on your remote control
Step 10) Press the Enter button on your remote control
Step 11) Your player should now place itself in Standby mode
Step 12) Press the Power On button on your remote control
Please rate my answer if this helps,
Many thanks,
Chris
Mar 14, 2011 | Samsung HT-DS1000 System
Region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
Apr 25, 2009 | Televison & Video
I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Nov 29, 2008 | Audio Players & Recorders
posted by alfredsaviou
Nov 18, 2008 | Televison & Video
Region Codes
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
It should also work for HT-Z310T and HT-510T and its variantes...
Apr 12, 2008 | Samsung HT-Z310T Theater System
Televison & Video Logo
1,018 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
