Question about Maytag Washing Machines
Fills wahes but doesnt rinse or spin is it the fault of the timer?
I would check your water level switch function, it will be located at the end of a 1/4 inch flexible tubing coming from the washer drum, my past experience indicates the replacement of this assembly will restore operation to your unit.`
Posted on Apr 16, 2012
SOURCE: My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Posted on Oct 08, 2007
SOURCE: Help!! My maytag neptune MAH6700AWW is having trouble.
the fix was simple i just had to lift my drain hose off the floor. it had become disconnected from the back of the washer and was lying on the floor. I didn't realize that by it lying on the floor it didn't provide the proper back pressure to keep the water in while filling the tub. this was the NF error. as for the LE error. i haven't gotten it since i took off my cold water hose connection and ran hot water into it to losen the dirt/rust that was caked into the screen that is located in it. My washer is running like it is brand new again.
Posted on Feb 20, 2008
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
Oct 31, 2012 | Maytag Washing Machines
Aug 01, 2012 | Washing Machines
Apr 16, 2012 | Maytag Washing Machines
Jan 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Sep 22, 2009 | Maytag HAV3460AWW Top Load Washer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Oct 05, 2017 | Maytag Dependable Care LAT9706
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Jan 14, 2021 | Maytag Washing Machines
43 people viewed this question
