Check the air con drive belt is still OK.
Check to see if there is a slight change in the engine sound when the air con is switched on and off while idling - I'd get someone to do the switching while I listened under the hood.
If there's no change in sound (assuming whatever had to be switched on to enable air con to go, eg fan was operating) I'd check the fuse(s) for the air con.
If the fuse is ok, and you've already charged up the freon (not quite sure what you were saying there), I'd be taking it to an air con specialist.
Good Day , i hope you can help me, first of all i have absolutely no knoowledge of cars, i have a 2001 pegeout 206cc 2liter. so the problem is simple i hope, my air con goes on fine all lights show etc but it doesnt blow anything, i have checked fuses and all seem to be perfect, i cant find anything online showing me where i need to get my hands dirty to fix the issue, what could the problem be? the main fan by the radiater hhas that little fuse with a grid typr thing around it which i assume controls the level of the blower that also works fine, and its located in the front grid exsposed to everything like water dirt etc, the main issue is it does not blow, and when i turn it on i can hear some sort of click sound, also i dont know where to check the gas? if there is no refridgent gas will the blower still work? does anyone know what i can do or just give me a few steps to try, thank you Luke
HI KEVIN.oil from breather is no a good sign.sound like back pressure.but if there is no smoke any where give an engine flush and clean all return hoses and mesh filters.good luck.ali
they have problems with water ingress in to the injector closest to the timing belt and would replace this and to stop the water ingress you need to remove and re-seal the off side washer jet.
If the car makes the sound you say,try this.Turn the air/con off and on and see if the sound goes off and on.The car has an electric fan that comes on with the air/con to help cooling of the motor.It may also be the fans for the engine cooling system.If the car starts without the sound and it then kicks in later,its the cooling system working properly.Hope this helps
