The machine restarts when switch on and when you press the power button firmly you will see the error code E000, how do i resole this problem
SOURCE: canon imageclass d761 error code
additional function them the pound key, with the arrow look for the printer setting, hit the set key go to printer reset, hit the set key it will ask you yes or no press the left OR (YES) the printer will not do anything unolug them wait 3 second and plug it back it if this doesnt work you will need to have the fuser replace
SOURCE: Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister). IF YOU'RE GAME, here it is... To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
SOURCE: ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
SOURCE: Canon D880 Error -- E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
SOURCE: Error code E000 on a canon imageclass D761
in service mode (additional function then pound sign) go to number 7 hit set go to 4 hit set push left arrow for yes set then unplug and replug
