SOURCE: No sound from altec lansing ada745, was working
try to update the audio driver of the computer. you can download the latest audio driver from your computer manufacturer's web site then restart your computer.
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
SOURCE: I need to know fuse # for Altec Lansing ADA745, and were to get i
the specs on mine are #239 1 amp 250volt. this is a fast burn fuse. you can find it any radio shack.hope this helps.
i have the power light on the main speaker. I looked at the fuse but it still looks new after 10 years. I have tried two different compters because I thought it may have been the onboard speaker(green) plugin. I tried a extension on the speaker cable plug that is internal from the woofer. that did not work in either computer or even in the headphone jacks on each computer. let me know if you come up with something. I heard somewhere that perhaps the system board inside the woofer is bad. I will look and see if it is replaceable. I cheapest i saw was a reconditioned Altec lansing ADA745 for $285.00! :-(
