You should be able to open the door manually with the key and you may have to turn it twice. Also try unlocking it whilst at the same time pulling on the door handle to the opening position or pulling the door handle to the opening position and then working the lock to open it manually. One way or the other it is designed to be opened manually with the key when there is a power failure with the power operated central locking not then operable.
The key blade is to open drivers door and glove box only, you did not specifie what model and year of car you have. on most smart key Nissans there should be a port to put the fob in if fob battery is dead
check that the cable did not jump out behind the lever. also ,some cars have electric/ semi electric systems where you need to switch on the key to open the bonnet or the bonnet has a fuse which could be blown. check fuses.
When the battery goes flat on a rapide the windows are up. The doors are frameless so the windows are located in the seals in the door aperture. You cannot open the doors and you cannot open the boot. Look through the front grille towards the radiator with a torch and you will see the bonnet release cable outer sheath. If you pull the outer sheath it will put enough tension on the cable to release the bonnet catch. With the bonnet open you can charge the battery. Negative clip on the alternator casing and positive clip on the central charging stud.
hi did you get the resistor fixed if not you need to remove the glove box by removing the screws that can be seen then there are two plastic lugs that need to be pulled out sideways to enable you to remove the glove box then you will see the resistor card on the side of the motor thats on the new shape micra k12
keys need to be programmed using a diagnostic computer and the keys need to be in good working order.
There is an over ride manual opening on the passenger door (remove plastic part of door handle).
Some lock out kits have a stiffer long bar that you can sneak all the way over to the opposite door to hit the open button. Perhaps something like that could hit the switch in the middle.
same problem
Same problem, I had trouble starting the engine and now the battery has died and I can't even get in my car, help!
I have the same problem. My engine wouldn't start and now the battery has died so I can't even get the car doors open, help please!!
Nissan interstar 2006
