SOURCE: Can I use the Netgear Rangemax wireless router as an access point?
Yes you can use it as an access point and hook it to your existing router, since this is a wireless router and can work as a wireless access point on your network............
SOURCE: Trying to connect wpn824 router though dsl with Windows 2000
First make sure that you can access internet through the router when connected to it wired. If yes, then please perform the steps below to configure settings:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'.
6. Set the 'Authentication Type' as automatic.
7. Set the 'Encryption Strength' as 64-bit.
8. In Key 1 type a 10 digit number.
9. Apply the settings.
10. Click on Wireless Settings under Advanced in the left hand side menu.
11.. Click on Setup Access List. Uncheck the option Turn Access Control on and click apply.
Scan for the wireless network on the computer with the wireless adapter and connect to your network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
