I opened my laptop today and i turned it on and the screen was completely white
Power down the laptop (press and hold the power button).
Try turning it back on, and hitting the F8 key to get boot options. Start in "Safe Mode" or some other configuration that worked and see if that fixes the issue.
If the screen does not show anything at all, try connecting the laptop to an external monitor while starting up.
SOURCE: white screen problem in acer aspire 4710
You will have to disconnect and reconnect the video signal plug located under the upper cover (the one with the power button on it). Best you start with a screwdriver in the very corner).
See also: http://blog.shimpossible.com/2007/07/18/white-screen-of-death/
Additionally I removed a small magnet located under the lid cover (remove 6 screws under rubber placers and lift the lid), which I found next to the video cabling. This could have affected the video signal negatively. Lets see how long this fix lasts.....
SOURCE: acer aspire 5520 startup problem
Michelle-
I had the same problem with the cursor jumping around. My cousin bought the same computer and had the same problem! What she told me to do was go to the touchpad icon on the bottom right. Then click tapping and then check the box that says "tap off when typing."
It seems to have worked for us.
SOURCE: No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
