Battery not holding a charge
Any ideas how to fix this or where to purchase a battery?
Posted by bjpepsigirl on
Chris Hingee
  • 32,281 Answers
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Since you did not supply details of your device and the type of battery I cannot advise where to purchase the battery.
I suggest you Google the Internet for the rechargeable battery you require.
Posted on Apr 16, 2012
Old batteries started not to hold a charge very long. I purchase 2 new batterys and still have the same problem. NOTE- i WAS USING MY TOOLS outside in 100 plus degree heat for weeks.
does the charger check out? use a volt ohm meter to check the chargers output. when you charge all four batteries us the meter to check the batteries charge. this should give you an idea where the problem is.
Aug 26, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
The unit is no longer recharging, I need to
Sorry about this but the batteries for this seem to be discontinued and are no longer available. A quick rumage around on google for a GDVD70W6 Battery 7.4V 2600mAh 456295 YOKU info from www.chsinteractive.co.uk just keeps coming back with the same answer.
Regards, James
Apr 19, 2010 | Goodmans GDVD70W6 DVD Player
When I plug the AC plug into my computer, the battery light doesn't appear that it's charging. I purchased a new battery and still doesnt charge. any ideas?
try to darin the batter first. heres the procedure. take out the battery and unplugged the power adapter. press and hold the power button for 30secs. after 30 sces, put the battery and adapter back in. then power on the computer and observe.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 01, 2010 | Toshiba Satellite A135-S4527 Notebook
Batterys wont hold a charge
It's never a good idea to ship a scanner (or anything else) with the batteries installed, as you never know what the package might experience enroute. About all you can do is replace the rechargeables with fresh NiMH batteries. If they don't take or hold a good charge you need to contact the company that "fixed" the scanner.
BillB
Jan 12, 2010 | Radio Shack Pro-96 Scanner
Willnot hold battery charge
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
If you have only had it for 4 days, is it not under guarantee?
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Jazz Cameras
Battery doesn't charge.
the power supply may not be delivering the necessary power to charge your battery.
Jun 02, 2009 | HP Compaq nx9600 Notebook
Will not hold charge
you need to change the battery...
May 14, 2009 | Samsung SCH-u340 Cellular Phone
Batteries won't hold a charge
Are the batteries really gettin a full charge or is your charger faulty. If you can borrow a voltage meter you can see what your battery is putting out and check the charger (plugged in) to test how much voltage it is putting out. If the Razor is 12 volt you can hook up a car/motorcycle charger to pump up those batteries. I don't think your batts are not holding a charge, i think they're not gettin a charge....good luck to you...Tim
Apr 18, 2009 | Razor MX500 Dirt Rocket
T21 will not run off battery
Either you got another bad battery, or the power bar in the laptop isn't distributing power correctly.
That's about the only options.
If you can, check the pins for current where the battery plugs in, to see if it's getting juice.
Good luck
Dec 03, 2007 | IBM ThinkPad T21 Notebook
Televison & Video Logo
1,258 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
