Question about Motorola Mag One BPR40 Two Way Radio
I have 6 gp328 and my multi charger power supply burned i guess due to the variying of frequency, can i use diffrent power supply with the same output voltage of the burned power supply?
Posted by Brian on
steven sikora
    New Friend:
    Problem Solver:
  • 6 Answers
Yes you can. So long as voltage is the same. Replacement power supply runs about $120.00. Also make sure replacement power supply has the same current capabilities as original
Posted on Oct 14, 2013
2 Related Answers
eradiostore
eradiostore
  • 1658 Answers
SOURCE: lost power supply
We couldn't find the info regarding output/voltage. However, there is an online vendor offering replacement chargers/batteries for the T5500. Here is the link, look toward the bottom of the page for the chargers. http://www.csonline.net/crawford/motorola_talkabout_T5500.htm
Posted on Jan 30, 2009
n_kan
  • 22 Answers
SOURCE: hi i have got a
you can contact the service provide........
Posted on Jul 08, 2011
Error tone in gp328 plus radio
Generally due to power low. It may also be a PPL issue, this should be checked out by a radio repair shop. Did you get the set wet or damp?
Apr 20, 2014 | Radio Communications
I'm looking t buy an XC1000 cable to power my zv5000 but the price is ridiculous-$175 or more for what HP used to charge $45 for! Is there a less expensive alternative?
Well check on ebay,,if not you can go to electronic store and buy a multi charger for laptops,,i got a compaq multi charger ,,has adapters for bunch of diffrent models of theres,,,check ebay for that also,,,goodluck
Nov 20, 2010 | Compaq Presario R3000 Notebook
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
Communication Between the GP328 AND GP339
you need to know what band is every radio, if are for the same band, then can be programmed to the same frequency.
Jan 10, 2010 | Radio Communications
My laptop wont turn on or charge
Let's rule out the charger.
Find a multi-meter and check the voltage. It should be listed on the power supply what the output is. For instance, I have Dell that outputs 19.5v.
You can find a multi-meter at Radio Shack, Wal-Mart, etc. Just plug the red lead into the center of the end of the cable and the black one onto the metal 'barrel' surrounding the power supply 'jack'.
Your multi-meter should be set to 200v DC.
If your power supply is outputting near the output it should, your power supply is probably good and it is going to boil down to a bad DC input on the mainboard of the laptop.
Mar 22, 2008 | Acer TravelMate 4150LCi Notebook
Panasonic vertical output
it is due to high voltage output from flyback transformer
so please check output supply from power supply output.
if it is ok every thing will be normal.
good luck.
Oct 17, 2007 | Panasonic CT-32SL14 32" TV
JVCAV-N2043TV,Horiontal Output Transistor burns out everytime if fix a new one
Hi There,
The Hor Output transistor is connected to the Line Output Transformer. This transfromer provides a lot of voltages around your TV set but includes the very high voltage to the Picture tube...
These transformers are specially tuned to resonate at a certain frequency,
The Hor output transistor needs to match this frequency....so if the wiring inside the transformer is shorted by "just a bit" the picture will be visible but the transistor is struggling to match the transformer impedance,from the mismatched tuning...so the transistor draws more current from the power supply.. runs hot then burns out...
Usually manufacturers provide a Trip circuit that detects that an overload on the power supply is occuring and cuts the power to the Line output stage ...this is usually detected by a clicking sound within the power supply its called hiccuping.
If some one has altered the correct setting on the power trip circuit then the next thing that happens is the Transistor goes Blooooey like in your case.....
So to save you a lot of money replacing the output transistor
please replace the output transfromer as well next time...
But please... please... re-check the power supply trip circuit to save you a lot more expense in the future....
Best Regards From YUBEUT
Oct 10, 2007 | JVC AV-27230 27" TV
Motorola Mag One BPR40 Two Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
