I have an samsung lw20m21cp , and when i put tv cable the brightness is to high , and when i connect to pc is working good
Hi same here
The cables want to be in their correct place. After you have made sure that the cables and plugs are in their place. Check the input on the remote control. If your connection through the antenna and the the remote does ot show that,move to the antenna input.
The same method goes for the HDMI or ADSL Broadband or what.
Move to the correct input. OH and another matter, check that the scart plugs are iwhere they should be.
Good luck
kolbrun
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
SOURCE: Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you:
0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid
2) know what you're doing with a soldering iron and teensie SMD parts
3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Testimonial: "Good advice, but didn't work. :("
What method do you use to connect? Is it different for cable than for pc?HDMI, composite, vga, svideo?
