Question about AOpen Computers & Internet
I have an AOpen i945Pa-plf mainboard and i,m rying to install a sata hard drive and a sata dvd burner (LG litescribe). It will detect the drives but will reboot during the start up process when i try to format the WD sata drive. What are the settings in cmos to correct th-s problem?
Posted by Nelson Davis on
5 Related Answers
Anonymous
  • 1226 Answers
SOURCE: how to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Posted on Feb 20, 2008
IQUIT
  • 3940 Answers
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
Posted on May 19, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 28, 2008
Anonymous
  • 1124 Answers
SOURCE: Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Posted on Oct 22, 2008
Cytherian
Gary
  • 124 Answers
SOURCE: How to install new hard drive
Hi Mark,
External drives have come a long way and run almost as fast as many internal drives. If your need for extra hard drive space is pretty much driven by the Microsoft Flight Simulator game, you could get by with using an external drive. A few things, though: Make sure your system is supporting USB 2.0 (it should be) and that the drive runs at least 5400rpm. External HDD's run off standard 120v AC power.
Otherwise, if you want to get an internal drive, you can certainly get another ATA-133 drive. But SATA is faster and your computer may support it. The D530 CMT (convertible mini-tower) definitely does. But there is also the D530 SFF (small form factor), and D530 USD (ultra slim desktop)--not sure if those are rigged for SATA support.
As for maximum hard disk size supported, that's up to the operating system (e.g. Windows XP vs. Vista). You likely won't need any bios updates because of a new hard drive installation. However, its not a bad idea to review the BIOS update release notes to see what they're addressing.
Posted on Dec 30, 2008
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
Not apearing to the computer
Hi Good day!! maybe it is not detected by your board. try to pull out the sata cable or replace your sata cable and see if it works
Dec 04, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
It is not detected as a DVD it is only labeled as a standard CD thought DVD's can be read but burnt, how can i fix that problem?, i already tried downloading drivers from AOpen.com but everything remains...
Have you checked how the drive is listed in device manager? You may need to find the Firmware for your model of drive and Flash it. This usually isn't as hard or scary as it sounds. :)
Jul 17, 2010 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
LG GH20
did you get and cd along with the drive from where you bought it ??
try to see in that ..the driver must be surely present there....
btw what is the operating system you are running on your dell...most of the operating system automatically detects any hardware changes....
just also see in bios whether your drive is detected at start up.
Sep 14, 2008 | LG (GH20NS) DVD±RW Dual Layer Burner
SATA HDD
you need to install the drivers for it when loading windows,,
you are on the right track by pressing F6 however you need to have the FLOPPY DISK that came with your mainboard in the floppy drive..
If you dont have the diskette then ,, the drivers are located on the mainboard cd,, its in the sata / raid folder, there should be a text document in there with the insttructions on creating a floppy with the driver files you will need.
Jul 19, 2008 | AOpen AX4B-533 Motherboard
Software problem lg gsa-h55l
well if it is home basic vista it mite not be compatable mite go to web site of the comapny you bought the CDRW from and ask them if the have a compatiable driver with vista? lala linda
Jun 01, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
Light Scribe is not detected
I Have had this problem as well.  First, go to nero's website, and download the latest version for your edition I know that if you use Nero 7 if wont work without the update.  Also, check and make sure that you have the latest drivers and firmware for the drive, as this can also cause it to not be detected.  Also, try a different Litescribe program, and see if it works that way.
Jan 10, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Thomas
Michael Thomas
Joe Goldman
Joe Goldman
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
