Question about Humax DRT800 TiVo Video Recorder
How do I connect my Humax TiVo Dvr to to the free dish network apartment system?
Posted by Lannie Green on
Mike.H-DISH_Network
  • Humax Expert
  • 246 Answers
Hi Lannie, my name is Mike Houston a Social MediaRepresentative at DISH. Connecting a TiVo box to an existing DISH connectionwill depend on a couple of things. Is there a DISH receiver in the apartment?What kind of connections do you have for the TV, HDMI, RCA, or Coax connections?I will send you my e-mail so I can assist you better; [email protected]
Posted on May 13, 2012
3 Related Answers
Anonymous
  • 42 Answers
SOURCE: Humax Tivo will not record to DVD
After the update to 1.15 I had to delete EVERY recording on the unit. After that, any new recordings would burn just fine. However, some have found that same failure even after a hard reboot (repower). Called Humax level-1 support and they suggested a replacement unit so I swapped it out. But I've since learned that TiVo "pushes" a DVD firmware patch (possible supplied by Humax) from 1.08 to 1.15 and that patch is the culprit. That patch is suppose to make the DVD burn at a higher spin rate. After talking with level-2 Humax support they heard of the problem and said "the unit is working as designed", meaning, the DVD drive manufacturer specs say the drive is capable of a faster burn rate. So now I have Humax DTR800 #2 and so-far-so-good, but TiVo hasn't pushed the patch onto the box yet!
Posted on Nov 10, 2007
Anonymous
SOURCE: No picture on Humax DRT400
Try taking the cover off and taking an air compressor and blowing it out real good. I have the exact same one and I had the exact same problem and after i blew it out it worked like new.
Posted on Mar 18, 2008
Anonymous
SOURCE: Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Posted on Aug 20, 2009
I need installation instructions for a tivo drt-400 humax dvr
No. There is no tuner in the Tivo . It will record cable or satellite but not off air antenna.
Nov 01, 2014 | Televison & Video
My Mother in Law switched off her Humax PVR9300T before going away for Christmas. When she switched it back on, the display now flashes blue then goes blank. Any ideas how to cure this anyone?
nigelweir
I have provided a link to the Humax Website. You can look through this Website for troubleshooting sets. I hope this helps.
http://www.humaxdigital.com/uk/products/product_stb_terrestrial_pvr9300t.aspx
Ray Calo
DISH Network
Jan 01, 2010 | DISH Network DVR-625 DTV Receiver /...
The rewind/ff/record and pause buttons won't work. Everything else seems fine.
This will be due to either your Hard Drive crashing if you cant also access your recordings. if so then i would reccommend call dish At 800-333-3474 bercause your 721 DVR is outdated and discontinued. It also is in patent dispute with tivo. When you contact dish they will offer you a new dual tuner DVR reciver with way more recording time. this upgrade should be free of charge as well.
Nov 05, 2009 | DISH Network 721 DVR Remote Control
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
I can't find a Humax/Tivo repair service san francisco peninsula
Try [email protected] Services SF Bay Area (Peninsula, San Jose, East Bay). They make housecalls. Can repair and upgrade all Tivo's - Series 1, Series 2, Series 3 (including your Humax)
Apr 16, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
Mar 13, 2009 | Humax DRT800 DVD Recorder w/ 80 hr Tivo
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
TIVO HD DVR
OK, I had Dish network come out and install DVR HD. Had pixel des torsion viewing everything I recorded. They came out 3 time and replace DVR and check everything 3 time with no improvement. I had them remove everything.
I called Direct tv and they did the same thing. installed there dish and cables and DVR. Same problems. My question is? Is this the nature of this equipment or is there something they are missing.
Jul 11, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo Dtv
No, you need a regular directv receiver, or a directv w/ tivo receiver or a directv dvr.
Oct 03, 2007 | Tivo Humax® HUM-T2500Digital Video...
Humax DRT800 TiVo Video Recorder Logo
Top Humax Televison & Video Experts
NOEL
NOEL
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
