Where is the cmos located
SOURCE: where is the CMOS battery located on Acer Aspire
Bottom of the laptop, the big cover that comes off. Below the wlan card
Posted on Feb 18, 2009
SOURCE: CMOS Battery location/image for Acer Aspire 5610
The CMOS battery is located on the motherboard. You would almost have to take the complete thing apart before you find it. You would be better off downloading password recovery software like OphCrack. It's free as an .iso file so you would just burn it to a disc and it will find the password for you.
Pls rate this solution.
Posted on Apr 09, 2009
SOURCE: Cmos battery location in my acer aspire 3690
its inside the laptop motherboard, the shape is SPHERE or CIRCLE, its a Lithium Battery (CR2032), only technical support are going to open, if you wanted to open it... its your own risk.. Good luck!
Posted on Jul 12, 2009
SOURCE: aspire 5720z cmos battery location
unplug your computer and turn it upside down. there you will see the blue circle. release and slide the battery out.
Posted on Aug 22, 2009
SOURCE: Replacing CMOS battery - Acer aspire 3000
Before you begin, back up your data and remove the battery. CMOS Bios will be lost but will reset on restart.
Instructions
User Manual
Good Luck
Posted on Feb 15, 2010
Remove the
Phillips screws that secure the motherboard cover (refer to your owner's manual
if necessary), then release the cover from the clips on the bottom of the
plastic casing.
Lay the cover
aside, then locate the CMOS battery cable on the right side of the motherboard.
Unplug the cable, then remove the battery.
http://www.youtube.com/watch?v=cg_wvp1YdSI
laptop cmos battery
